i come across these transistors and was wondering if they can be usefull in an LTP or other stages of audio .....
it looks to me that they have very fine specs but really wonder if can be used BC 875-6-7-8-9-0 are complementary NPN -PNP DARLIGTONS + DIODE operatind at 100 v 0.8 w 200 MHZ and beta of 2000 what do you think ???? thanks
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
too much of gain ?
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3 | |
Regs Fotis |
#4 |
First of all, i have not idea about mosfets and my experience it is limitted mainly in ONsemi devices.
According to use, i prefer these: 1) For P.A. amplifiers and according to supply level: Small signal stages MPSA06 - 56 or 2N5401 - 5551 VAS & Predrivers MJE15030 - 31 - 32 - 33 Main drivers MJ15020 - 21 or MJL3281 - 1503 Output stage MJ1503 - 04 - 22 - 23 - 24 - 25 2) For Hi-Fi amplifiers Small signal stages 2SA970 - 2SC2240 VAS & Predrivers the same as above Main drivers MJL3281 - 1503 Output stage MJL21193 - 94 3) For low power applications such preamps etc: BC550 - 560 D44H8 - 45H8 4) For bias in power amplifiers BD135 or BD137 I have tried only the above devices, because i can find them (the same for you because Greece) very easy. You know as i think "BAKIS electronics" for OnSemi, Fischer etc etc. I am in waiting to hear your news. Fotis |
#5 |
thanks for all these info .....
this is more or less what i use in my amps too but these specs seemed to look like something really special and so i thought that might be used in some audio application .... of course if so a circuit needs to be builted around them
#6 |
the MJE1503x series have far too much Cob for VAS duty. Similarly the Power capability is wasted in VAS and pre-driver duty. Use a low capacitance, lower power, medium hFE, high fT device in these locations. Try 2sa1360/c3423 and many that are similar for VAS & Pre-drivers |
#7 | |
Probably you are right in your suggestion. The problem it is where we can find 2SA1360/2SC3423 or similar in Europe. As i have mentioned above, the problem it is the availability of components, for this reason we prefer OnSemis because are offered from most shops in Eu. Regs Fotios |
#8 |
Fotios,
I agree with AndrewT. I use 2SC3423 as VAS; Cob is less than 2pF, 200MHz, 50mA, 120V, outstanding device. I've found low Cob is the single most significant parameter for VAS selection. Capacitance across the depletion layer is very nasty; high dielectric absorption, variability with Vce, and multiplied by beta of course in common emitter. I'm in a very different part of the world to you, but I buy from Peacock Electronics in Singapore. As you may be aware, the Far East pretty much controls the prices of semis in the world, and I find prices from this company very competitive. Expect to pay around 40c US for 1K+. Hugh |
#9 |
AKSA is right - low Cob is critical.
In Europe, you can try the SOT223 BF8xx N & P types from Philips (I think they are NXP now) |
#10 |
Few years ago I used for a custom amp transistors pulled from oscilloscope, they were 250V 200 MHz devices. I don't remember their names, but surnames were Toshiba.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
| Help understanding a driver stage with extra transistors | rtarbell | Solid State | 1 | 24th July 2008 03:55 PM |
| Adding more transistors to output stage? | bowdown | Solid State | 6 | 19th January 2007 07:15 PM |
| High voltage transistors for VAS stage | rtarbell | Parts | 4 | 15th November 2005 12:13 AM |
| 5 transistors output stage | KCC | Solid State | 6 | 30th June 2003 01:52 PM |
| 50 Output Stage Transistors? | thylantyr | Solid State | 22 | 26th April 2003 10:44 PM |
