The Ping-Pong VAS
see what happens with the copy and paste :rolleyes:
Many thanks BV -->Very GOOD
you are a little genius
divide the functions is the best strategy
compensates for the differences effectively
in the current stage need just put other two LEDs on input
maybe need also two capacitors like A700 diy gene
your simulator can also put resistor's value?
:) :cool:
I don't think there is quite nothing new in these. You can look at the F5 from Pass which uses the exact same feedback scheme in his CFP output.
Actually, I am not sure it has any sort of advantage over the kind with only one feedback path in the middle. The simulation can tell if it's better or not, try it and let us know Stee. By the same way you can determine if putting emitter followers after the CFP is interesting distortion-wise, but I don't think it is since the gain is high enough in the usual CFP.
And after all, the best way to do a CFP could be with a total feedback (plain wire). Who really needs gain in the final stage? If you really want a gain of 4 after your opamp, you can also use a common base stage in between like in the musical fidelity amps.
http://www.diyaudio.com/forums/attachment.php?s=&postid=673432&stamp=1120201026
another OPA can solve this problem?
Hello to all
the purpose is not to set a gain (forcing a ratio on VAS)
the aim would be regular distinctly two branches (rails)
before they are added in the current stadium (stage)
to obtain two identical gains...
maybe use the primitive NFB is not a good idea
can solve this an operational from VAS
that can make difference and send result on input OPA?
