Little Class A ?
Little Class A ?
Old 30th August 2008, 03:22 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Little Class A ?
USE an OPA !
see this circuit
from cut and paste of an italian KIT
never tested
better have to connect twice CAR loudspeakers
because power is little
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 30th August 2008, 04:59 PM   #2
nikwal is offline nikwal  Sweden
oh man, that looks old, are thoose really silicon transistors? hmm well I guess it's possible.
I have two lm12's deep in the cellar, I'd like to do something like that with them some day just for the hell of it.. 80watt driving something hmm, that gives some weird thoughts in my head :-D
http://dsl.mine.nu (very enironmental friendly 5watt damn small linux server made from a compaq t1010 terminal)..
Old 30th August 2008, 05:58 PM   #3
Stee's Avatar
Default discrete op-amp --> the solution
Working voltage: +/-25v DC
http://www.bursonaudio.com/Burson_HDAM_Module.htm
http://www.audio-gd.com/enweb/pro/diy/OPA.htm
that is good to have an accurate VAS
with a domestic power
need just design a current stage in class A
easy with LED's polarization
you have to select numbers and color!
...the problem is thermal drift control
maybe a very big dissipator it's a way
or see this current stage with IGBT
http://www.diyaudio.com/forums/showt...hreadid=128784
Old 30th August 2008, 10:24 PM   #4
Stee's Avatar
Default again without drift correction
a variation of Elliot
Old 1st September 2008, 09:04 PM   #5
Stee's Avatar
Default IGBT version
hello
this can be famous until a season...
(copy from esp - australia)
Old 1st September 2008, 10:19 PM   #6
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Default Re: IGBT version
Not quite sure why it is class A. The output stage is classA, what about the OPAMP, its crossover distortion will simply be amplified, what is the point?
Old 2nd September 2008, 06:05 AM   #7
Stee's Avatar
Default Hi
i think the OP-Amp works in class A also final stage
see version two
maybe 5A biasing is too much?
(5A x 30V = 150W for one device on dissipator)
Little Class A ?Hide this!Advertise here!
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
