New amp sounds too controlled ... what to fix - Page 2 - diyAudio
Old 29th August 2008, 02:39 PM   #11
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
quote
"Just bought a new AV amp from Yamaha but the sound is too controlled, its killing the expressive musical quality of the music."
unquote
Try a glass of Aussie red about 20 minutes before your listening session.
Works wonders mate.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 29th August 2008, 02:54 PM   #12
h_a is offline h_a  Europe
h_a's Avatar
Reducing the damping factor will diminish the control of the amp on the woofer thus letting it move more in its own will
Not exactly like that, I refer to D. Self. The passive crossover really cooks damping factor down. As does the usual Zobel.
Now that's some real advice.
A lot of amp shortcomings can be fixed that way. Unfortunately it's not permanent.
Have fun, Hannes
High Octane phono preamp Wiki
Old 29th August 2008, 06:19 PM   #13
Coolin is offline Coolin  Netherlands
Coolin's Avatar
Thumbs up PROBLEM SOLVED !! Back EMF
Hey guys it actually IS the damping factor.
Now I've got very lightweight cones so this could be the reason its so audible but using the resistor really works !
But dont use it in series ! It improved the low end but not much more than that. Use it Parallel. My reasoning is it gives the back emf (motion from the cone without applied signal) from the drivers a chance damp in the resistor as the amps resistance is too high to be of any good.
Now while it is a good solution sound wise i still dont like it..
What can be done to the amp itself to lessen the damping factor??
There are indeed ams with adjustable damping factors, that would be nice but not practical for this amp..
Picture of the output stage coming next . Looks pretty standard to me but i know very little
Can someone point me to information ?
Thanks, Collin
Old 29th August 2008, 06:23 PM   #14
PMA is offline PMA  Europe
PMA's Avatar
The best solution is another amplifier, or ...
Old 29th August 2008, 06:30 PM   #15
a damping factor of 120 sounds quite normal.
What impedance is that into?
How does it vary with frequency?
Adding half an ohm in series with the speaker cable will reduce the damping factor to lower than just about any SS amp on the market.
But it will also alter the Q of the speaker and may sound a bit boomy after adding the resistor.
Have you read the ESP site yet?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th August 2008, 06:33 PM   #16
Coolin's Avatar
Question output stage
The sound is now close to the sony amp. Still a little more compressed though
Old 29th August 2008, 06:40 PM   #17
Coolin's Avatar
I saw a curve for a different model Yamaha someone measured and it was lower in the bass area but still somewhere around 50 or so.
It was actually 6,8 Ohm ! in series. Ive gor 15 ohm in Parralel now.
A long time ago, going to check it again...
Old 29th August 2008, 07:35 PM   #18
Coolin's Avatar
[/B]
Yes the sony amp sounded boomy with a different bass driver..
This experience i speak of are with pro drivers, light weight and heavy motors, low Qes.
I guess every extra Hz you can get out a driver with a high Fs has a big impact. Still, it worked for the midrange driver as well, also very light cone.
!!!!! So could this be the heavenly match between tube amps and high eff. drivers !!!!!
Gr, Collin
Old 30th August 2008, 12:10 AM   #19
Coolin, you said it improved when you put 15 ohms in parallel. That actually increases the damping seen by the speakers, though not by much. My guess is the amp is now supplying more current (you have to drive both the resistor and the speakers) and maybe the amp isn't very good at low power levels- it just likes working a bit harder, or it doesn't like the cables, the speakers or something. As long as the combined value isn't too low, I'd just leave the resistor in parallel.
I may be barking up the wrong tree, but at least I'm barking!
Old 30th August 2008, 12:48 AM   #20
Banned
I strongly suspect the notorious Japanese commercial amplifier philosophy of huge open-loop gain an GNF resulting in an extremely clean, lifeless sound without any kind of warmth, spirit and dimension. The musical qualities can thereby be rated as negligible.
Remote Controlled CD-Rom Controller john65b Swap Meet 5 31st May 2009 04:03 AM
MCU controlled DC Protect for SKA gbyleveldt Solid State 3 12th October 2006 06:55 PM
DC Controlled AC Dimmer? imix500 Parts 6 9th January 2006 11:54 AM
Remote Controlled Tube Amp SHiFTY Tubes / Valves 4 16th February 2003 10:58 PM
Copyright 1999-2017 diyAudio
