120 Volt psu PreAmp - lowest possible G-FeedBack
Old 29th August 2008, 12:42 AM   #11
lineup is offline lineup  Sweden
lineup's Avatar
Thumbs up The Voltage Supply = 120 VDC regulated
As this amplifier needs a well regulated power supply
at 120 Volt Direct Current, DC
... which is pretty high, except in compare to great Tube / Valves circuits
.. I will use my own precision 120 Volt Discrete Regulator
as this regulator has been posted already twice ( 2 times )
i need not post it here again
my readers will have it in their collection of good discrete regulated power supply schematics,
in the folder named: Lineup Circuits
basically uses one TL431 for good temp stabilty reference
File Type: png 120vpre_voltage_supply_120vdc.png (486 Bytes, 432 views)
lineup
Old 29th August 2008, 01:34 AM   #12
GK is offline GK  Australia
Default Re: The Voltage Supply = 120 VDC regulated
Nice, revealing schematic Lineup.
You really like to keep us all in suspense, don't you?
Glen
Old 29th August 2008, 02:14 AM   #13
KSTR is offline KSTR  Germany
KSTR's Avatar
In German that's called "Salamitaktik"...
BTW, SoundPerformanceLab, a german based studio gear maker, have discrete op-amps in many of their products, using +-60V rails...
- Klaus
Old 29th August 2008, 04:43 AM   #14
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Interesting discussion here about supply rails. In my discrete op-amp cct (in the 'real men dont use . . . ' thread), I also run with quite high rails - 25 to 35V either side of 0V. At +-15, distortion simulates at about 10ppm. If the rails are taken up to +-30 or 35V, the distorion drops to <1ppm.
Of course, academic issue at these levels, but I have not managedto work out why (BTW, I checked this with f/back - I have not checked the open loop situation).
Hmmm?
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 29th August 2008, 10:21 AM   #15
homemodder is offline homemodder  Portugal
Bonsai nice opamp.
Nelson Pass has mentioned the increase of supply voltage to increase performanse in his paper about opamps.
In my view it has not so much to do with the circuit but with the characteristics of the components eg trannies. Using transistors near their optimum operating specs have advantages. Have a look at datasheets eg. in the case of higher voltages look at how capacitances drop at higher voltages. Transistor theory will tell more. As with semiconductors im pretty sure their will be some downfalls too, thinking of noise.
Harmonic distortion content can even be manipulated to a more favourable or better say user or subjective preferred spectrum to a certain degree using diffirent trannies in a certain position or operating at different voltages, thats for those that are more subjective.
Glen could probably tell us more on this.
Old 29th August 2008, 11:18 AM   #16
Higher rail voltages for a given output voltage swing and transistor type gives you less distortion (particularly from the VAS) because the percentage of Vce variation is less.
You get less of Hawksford's "slope distortion".
Glen
Old 29th August 2008, 02:25 PM   #17
Bonsai's Avatar
Homemodder - thnks
Glen - yes, this is one of the reasons I used a Hawsford VAS stage. I was hoping to be able to find another 1 or 2 places in the cct where I could take out a few more hundred ppb - but I could not find it despite a good few hours of work.
bonsai
Old 29th August 2008, 03:48 PM   #18
PigletsDad is offline PigletsDad  United Kingdom
PigletsDad's Avatar
lineup, the transistors you are planning to use have a maximum rating of 120V, and you are proposing a 120V supply rail.
This doesn't give a lot of safety margin for transients, voltage spikes and the like. Would it be more reliable if you dropped the supply rail to say 110V or even 100V?
Old 29th August 2008, 03:56 PM   #19
lineup's Avatar
the voltage gain in my prototype
will be
x 20 (= + 26 dB)
this is not in any way effected by if you use Feedback or No Feedback
the figure is all the same, to the decimal:
The output Voltage will be 20 times higher
than input voltage
the final testing is done at output level:
20 Volt RMS (= +- 28.3 Volt peak)
File Type: png 120vpre_voltag-gain_divider.png (597 Bytes, 363 views)
lineup
Old 29th August 2008, 06:58 PM   #20
fotios is offline fotios  Greece
fotios's Avatar
Default 2sc2240 - 2sa970
I have used already these bjts in the improved version of my amplifier by substituting MPSA06-MPSA56 with these in small signal stages.
Great improvement. The rise time it is now 1,47žs instead with MPSAs was 1,9žs (under the same drive signal and load).
2N5551-2N5401 are real "factory workers". I have used them also in my high power (thus with supply rails up to +/-90Vdc) P.A. type amplifiers with success.
My place was - from the first, when i was registered in diyaudio forum - that the bigger the supply voltage level, the bigger the dynamic range the bigger the headroom, etc, etc, etc......
Lineup, he knows.
Fotios
Best Regards FOTIS ANAGNOSTOU
120 Volt psu PreAmp - lowest possible G-FeedBackHide this!Advertise here!
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
12 volt preamp beamnet Tubes / Valves 11 5th January 2006 09:25 AM
Attenuator via feedback in preamp DarkOne Pass Labs 3 13th August 2004 04:08 PM
9 volt powered pocket mic preamp circuit example grovel darren01 Chip Amps 0 5th March 2004 10:05 PM
12 volt tube preamp help blackreplica Tubes / Valves 5 23rd December 2003 09:56 PM
Copyright ©1999-2017 diyAudio
