LM12CL 80Watts Opamp
Old 25th March 2003, 07:12 AM   #1
corbato is offline corbato  India
corbato's Avatar
Default LM12CL 80Watts Opamp
Has anybody tried this IC as an audio amp? Date Sheet Link
I looking at them as the amp for driving the lower half in my proposed Bi-amp system. The upper half will be driven by an UL 6V6 PP. XO will be Steve Bench 6DJ8 design.
I have already completed the 6V6 and find the output power amazing. My earlier plan was to use LM3875 to drive the bass, however after listening to the 6V6 PP, I am inclined to go for a higher power amp instead. I am looking for a cheap solution.
Thanks is advance.
Old 25th March 2003, 07:51 AM   #2
Dirk is offline Dirk  Belgium
I used the LM12CLK as a power amp several years ago (standard application note) without any problem. While I was able to get it real cheap, the LM12 usually is very expensive (I saw them priced at 50$).
Dirk
Old 25th March 2003, 01:40 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default you can bridge the single chip amps
National Semi has an article on bridging the LM3886.
Old 25th March 2003, 01:46 PM   #4
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
in israel the LM12 is cost a 20$
and u can bridge 2 of the LM and get 240W !i can give u a circuit if u want...
Old 25th March 2003, 04:50 PM   #5
corbato's Avatar
Default lm12
Dirk
Thanks for confirming its usabilty as a power-amp without any hitch, but are you sure about that cost. In India my supplier has confirmed at approx US$18
jackinnj
LM3875 is an option. Best part is I get the chip free
Dj BASS AMP
While I'd love to have your bridged schema, my requirement at the moment is rather modest But let me commend you for keeping the flame alive at this forum regarding higher powered amps Enjoy your posts and pics a lot.
Old 25th March 2003, 06:20 PM   #6
Account Disabled
Hii corbato...
if u want to connect to 4 ohm speakers u will get high power*
*= u be need a big heatsink !
Simple, Small and High power Amplifier...
Old 25th March 2003, 06:31 PM   #7
joensd is offline joensd  Germany
You obiously mean a bigger one than the cute one shown!?
Jens
Old 15th April 2005, 06:57 AM   #8
tigerbuger is offline tigerbuger  China
Hi,Dirk:
Did U have LM12 circuit for u diy pow amp?
LM12CL 80Watts OpampHide this!Advertise here!
Audiosource Amp One 80Watts X 2 (200Watts Mono) idex Swap Meet 12 12th August 2008 04:13 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 11:49 AM
LM12CL as an amp ??? la9 Chip Amps 10 14th October 2004 03:41 AM
Limit power to 80watts RMS from 180-20,000Hz SkinnyBoy Solid State 6 18th July 2003 01:47 AM
