I love the sound of this amp but unfortunately it has developed two large problems. First, the left channel has become distorted and is also emitting a whistling sound. Secondly, I am now getting no output from the phono stage on either channel. I am hoping these are repairs I can make myself or at least get the proper replacement parts. Thanks, David
#2 |
If you can post a circuit anything is possible. Those two faults sound a bit unrelated -- it's not been dropped or had spillage has it
#3 |
If you're lucky X-pro will notice - he designed the thing
#4 |
I am new to this forum and am in the eastern United States. I read about problems with the mute switch bit pushing the switch in and out has no effect on the aforementioned problem. I would like to know also if the 30 watt version the Mk3se has similar sound characteristics as the A3i as their is an inexpensive UK one in New York on sale. I also have never used a UK plug to US 100volt power converter. If I buy this other one is that conversion safe and if so, will the amp run cool enough. I would rather fix the one I have but I want to make sure it would be worth the time and expense. Advice on both amps appreciated. And btw phono stage is very important to me. TIA for your help/
#5 |
Never heard the Cambridge amps so can't comment there. As for 110 to 230volt conversion. You mean a step up transformer ? Providing it's suitable rated I can't see any real problem providing the amp is fed with it's rated voltage -/+ 10% . Do the transformers in the amps themselves not have the option of selecting different taps to accomodate different voltages. That's a much better option, or even replacing the transformer. As for fixing the amp -- if it has a genuine fault you may struggle by the sound of it-- you need to post a circuit here. |
#6 | |
I've sent an email to you - please reply and I'll provide you with a schematic diagram. There is also another thread I've started about A3i: Cambridge Audio A3i repairs and mods Cheers Alex |
| My Cambridge Audio A5 Amplifier | holdenwright | Solid State | 19 | 11th February 2011 06:27 PM |
| tweaking cambridge audio A5 integrated amp | quad99er | Solid State | 0 | 12th July 2009 04:09 PM |
| Cambridge Audio A5 Amplifier Repair | cahillj | Solid State | 1 | 20th April 2009 06:07 PM |
| Cambridge audio A5 integrated amplifier schematic | cahillj | Solid State | 1 | 11th April 2009 01:54 AM |
| cambridge audio a3 i amplifier for sale | homertooties | Swap Meet | 2 | 12th November 2006 06:13 PM |
| Page generated in 0.12329 seconds (56.62% PHP - 43.38% MySQL) with 10 queries |
