Shunt or serie volume control
Old 21st September 2008, 01:11 PM   #11
maxpou is offline maxpou  Canada
maxpou's Avatar
Hi guys!
thank you for fast reply!
I use 23V supply voltage look at: http://www.diyaudio.com/forums/showt...07#post1524207
I'm not sure if i need a voltage gain stage, i change the DAC in CD player and i think that i have 1,4Vp-p output.
thank you! Maxpou
Old 21st September 2008, 04:47 PM   #12
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
maxpou,
I`d go for a simple stage in keeping with this one.
Old 19th November 2008, 11:33 PM   #13
maxpou's Avatar
Hi guys,
i found this website for calculate the resistors for my shunt attenuator, but what's the best serie value and how many DB between each step because i have 24 step. Thank you! Maxpou
http://homepages.tcp.co.uk/~nroberts/shunt.html
Old 20th November 2008, 08:32 AM   #14
R.I.P.
Hi Max,
do you know what range of attenuation values you currently use?
Design each step to suit your needs.
It could be done with equal steps of 1dB giving a total attenuation -23dB.
or
steps of 1.5dB giving -34.5dB
or
steps of 2dB giving -46dB.
or
unequal steps.
Use big steps in the range you rarely or never use and small steps in the range you typically use. eg, 0, -6, -12, -18, -20, -22, -24, -26, -29, -30, -31, -32, -33, -34, -35, -36, -37, -40, -43, -46, -50,
-55, -60, -70.
You choose what best suits your use and your system.
regards Andrew T.
Old 20th November 2008, 08:46 AM   #15
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
Originally posted by Lumba Ogir
maxpou,
Lumba, I'm happy to see you recommending JFET/bibolar CFP, the best input stage. Just make it differential, and everything's honky dory.
Old 20th November 2008, 09:24 AM   #16
Banned
Nelson,
I have been doing that for years. Now, how far are you prepared to go?
Old 20th November 2008, 09:37 AM   #17
R.I.P.
r14=0r0?
only 2.5V cascode voltage on the CFP?
regards Andrew T.
Old 20th November 2008, 09:42 AM   #18
R.I.P.
Originally posted by maxpou
Hi guys,
that calculator does not make it easy to have constant Zin, nor does it take account of the Zin of the next stage.
Find a better calculator.
regards Andrew T.
Old 20th November 2008, 10:22 AM   #19
Banned
Andrew,
R14 sets the (lowest) gain needed.
Right, it`s not much of a cascode voltage.
Old 20th November 2008, 11:34 PM   #20
maxpou's Avatar
Thank you AndrewT,
i have elma shunt step attenuator and i never used step attenuator before, somebody can tell me your value resistors please. Thank you! Maxpou
Shunt or serie volume controlHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
What resistor and potentiometer values for GC shunt volume control? sharpi31 Chip Amps 2 20th September 2007 07:23 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
