Old 18th August 2008, 04:48 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default The Twin Negative FeedBack Theory
hello designers!
was born a new theory that you can not ignore
since VAS the transition more delicate for signal
need natural Compensation for those who want a sound round
OF COURSE FOR COMLEMENTARY ARCHITECTURE
there is the problem of actual similarity of the couple
(even in the life of humanity)
a solution is to use pairs of low-power
because they are much closer
and a stadium load to mosfets
because reduce emphasys of driver
Another solution is to offer an identical load to mirror current
(also have voltage gain)
the new bright idea is to use a double NFB
in order to manage the different gain separately
before they mix in current stage
NOT in VAS as floating mode
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 18th August 2008, 06:24 PM   #2
BV is offline BV  Slovakia
Something wrong seems to me in schematic, if GND means ground.
Grounded driving point (common point of 100R rersistors)of output devices (drivers loaded with 100ohms to ground??), drivers and ouput transistors outside of NFB..
Old 18th August 2008, 06:54 PM   #3
The one and only
Nelson Pass's Avatar
You can take a look at the F5 for another example.
Old 19th August 2008, 07:48 AM   #4
Stee's Avatar
Default it's correct like this
Hello
GND on mosfets drivers is forced for TNFB (TwinNFB) reference
you can joint to transistor on output
it's not important
current stage is free from NFB because don't have gain in Voltage
Nelson I have seen F5
there are two NFB because it's balanced
this Sound's Revolution Amp have two NFB, one one each rail
for auto-adjusting different gain of PNP/NPN
in separate devices for better error-control
maybe (never tested)
Old 19th August 2008, 10:08 AM   #5
nikwal is offline nikwal  Sweden
Been there, done something like that, not really thinking about doing it again sometime in my recent amps.. (maybe much later)..
http://dsl.mine.nu (very enironmental friendly 5watt damn small linux server made from a compaq t1010 terminal)..
Old 21st August 2008, 05:29 AM   #6
Stee's Avatar
Default cannot works with mirror -- The GVA
but in this case maybe
see the GALACTICA VAS
of course in Class A biasing
File Type: jpg gva-galactica voltage amplification.jpg (30.7 KB, 407 views)
Old 21st August 2008, 06:41 AM   #7
Stee's Avatar
Default already exist in Current Stage
need just in Voltage
a local feedback
the aim is to reduce the work of the input operational stage
Old 21st August 2008, 06:54 AM   #8
GK is offline GK  Australia
Default Re: already exist in Current Stage
a local feedback
That is current limiting protection.
Tha aim to prevent the output stage from going ffzzzttt.
Glen
Old 21st August 2008, 09:31 PM   #9
Stee's Avatar
Default Thanks a lot Glen
but do you think it's intelligent
modify sensibility of this stage
to have double local feedback ( one for each rail ) ?
http://cgi.ebay.it/Bal-Class-A-Power...742.m153.l1262
http://www.esafono.it/a700.pdf
Old 21st August 2008, 09:58 PM   #10
lineup is offline lineup  Sweden
lineup's Avatar
Stee
just some friendly advice.
First,
you learn how to design some basic amplifiers, with transistors:
this will give you knowledge to know more
what we can do
what we can not do
what is good
what is not good
what is really problematic
what we never should do
what is usually the best to do
After this, you Stee,
can start making Mark Levinson clones, copy
And maybe one day even some great & working amplifiers based on your own interesting ideas.
But to get into the same league as Mark Levinson
is not what some new diy hobbyist will make very quickly.
Some would get close .. after many years.
Some would never make it .. no matter how long it takes.
What I have seen so far, is five or 10 ideas per day
.. only those posted
and not many of them would work in reality.
It is good to have ideas
but what is the use, if they go nowhere?
you tell me
regars from
Lineup
Lineup Audio Lab - a few good amplifier ideas & designs based on knowledge & experience
lineup
Negative Feedback? Binaural Tubes / Valves 15 12th March 2009 07:05 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 08:05 PM
Page generated in 0.10575 seconds (80.28% PHP - 19.72% MySQL) with 11 queries
