I am struggling to get this model into LT Spice's library. I tried using the 'opamp2' blank, bet its not working. Anyone know how to do it?
* BEGIN MODEL LME49860 *////////////////////////////////////////////////////////////////////// * (C) National Semiconductor, Corporation. * Models developed and under copyright by: * National Semiconductor, Corporation. *///////////////////////////////////////////////////////////////////// * Legal Notice: * The model may be copied, and distributed without any modifications; * however, reselling or licensing the material is illegal. * We reserve the right to make changes to the model without prior notice. * Pspice Models are provided "AS IS, WITH NO WARRANTY OF ANY KIND" *//////////////////////////////////////////////////////////////////// * PINOUT ORDER +IN -IN +V -V OUT * PINOUT ORDER 3 2 8 4 1 .SUBCKT LME49860 3 2 8 4 1 * NOTE THAT MODEL IS FOR ONE SECTION ONLY (A SECTION) OF * THE DUAL LME49860 * MODEL FEATURES INCLUDE OUTPUT SWING, OUTPUT CURRENT THRU * THE SUPPLY RAILS, OUTPUT CURRENT LIMIT, OPEN LOOP GAIN * AND PHASE WITH CLOAD EFFECTS, SLEW RATE, COMMON MODE * REJECTION WITH FREQ EFFECTS, POWER SUPPLY REJECTION WITH * FREQ EFFECTS, INPUT VOLTAGE NOISE WITH 1/F, INPUT CURRENT * NOISE WITH 1/F, INPUT BIAS CURRENT, OUTPUT IMPEDANCE, * INPUT COMMON MODE RANGE, INPUT CAPACITANCE, INPUT OFFSET * VOLTAGE WITH TEMPERATURE EFFECTS, AND QUIESCENT CURRENT * VERSUS VOLTAGE. * MODEL INCLUDES INPUT AND OUTPUT PROTECTION DIODES. Q26 9 10 11 QON Q27 12 10 13 QOP Q28 4 14 15 QOP Q29 8 16 17 QON I4 9 16 3E-3 I5 14 12 3E-3 R34 18 17 1 R35 15 18 1 C6 10 19 2.8P R36 19 10 1E3 G1 10 19 20 19 -1E-3 G2 21 19 22 23 -0.5E-2 R37 19 21 1.5E9 C7 20 24 15.33E-12 R38 20 21 1.9E3 E1 25 19 20 19 1 D2 25 21 DD R39 19 24 45 Q30 23 26 27 QIN Q31 22 28 29 QIN Q32 30 31 32 QCN R40 12 32 3.65E3 R41 23 33 220 R42 22 33 220 V7 9 34 0.75 R45 35 27 1 R46 35 29 1 R47 1 18 10 D1 34 33 DD D3 21 25 DD D4 36 9 DD D5 12 37 DD V8 36 21 1.5 V9 21 37 1.5 E6 38 0 9 0 1 E7 39 0 12 0 1 E8 40 0 41 0 1 R48 38 42 10E6 R49 39 43 10E6 R50 40 44 40E6 R51 0 42 10 R52 0 43 10 R53 0 44 40 E11 45 46 44 0 0.65 R54 47 41 1E3 R55 41 48 1E3 C10 38 42 1E-12 C11 39 43 1E-12 C12 40 44 0.4E-12 E12 49 45 43 0 0.30 E13 50 49 42 0 -0.62 R60 49 50 1E9 R61 45 49 1E9 R62 46 45 1E9 E22 47 0 2 0 1 E23 48 0 50 0 1 E24 51 52 53 54 17.5E-3 I7 0 54 1E-4 D6 54 0 DVN I8 0 53 1E-4 D7 53 0 DVN R63 26 50 19 R64 51 28 19 E25 12 0 4 0 1 E26 9 0 8 0 1 I9 8 4 5.8E-3 R65 4 8 19.23E3 E27 19 12 9 12 0.5 C13 2 0 3E-12 C14 50 0 3E-12 C15 50 2 0.25E-12 V10 52 2 87E-6 R67 13 16 1 R68 14 11 1 I13 50 0 -3.7313E-6 I14 2 0 -3.7313E-6 I15 12 31 3.442E-6 V12 35 30 -0.5 D8 55 26 DD D9 55 28 DD V13 55 12 1.45 I16 0 56 1E-3 D10 56 0 DD R104 0 56 1E9 V14 56 57 0.65 R105 0 57 1E9 R106 0 57 1E9 E28 46 3 57 0 1.133E-4 R107 3 46 1E9 D11 26 9 DD D12 28 9 DD D13 1 58 DD D14 59 1 DD R108 58 8 10 R109 4 59 10 .MODEL DVN D KF=1.6E-13 .MODEL DD D .MODEL QCN NPN .MODEL QIN NPN BF=45 KF=2E-17 .MODEL QON NPN BF=15 RC=55 .MODEL QOP PNP BF=15 RC=55 .ENDS * END MODEL LME49860 |
#2 |
have you tried to use it
or add it? i have used it and this spice model is very good, and give good match with datasheet figures i do not quite get your problem, Bonsai is it you just do not know for sure how to add it or you get some error messages from LTspice? Lineup ![]() Lineup audio board - with member's blogs
lineup |
#3 |
'is it you just do not know for sure how to add it'
Lineup, no - its me - I do not know how to do it. do you hve the model? |
#4 |
no
not in ltspice i just added that one to my multisim ( Electronics WorkBench = EWB ) in order to figure out and help you i have to read the instructions HELP for ltspice
lineup |
#5 |
Bonsai,
There are complete guides for this, and much more, in the LTspice usergroup in Yahoo. If yo start to use LTspice more often, it's a good idea to join the user group. Even the designer of LTspice joins that goup to answer questions. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#6 | |
Bonsai.
I found this in Ltspice -> HELP - > Contents -> FAQ -> Third-Party Model I guess this should be enough for you to get it work. Quote:
Lineup ![]() Lineup Audio Community _ audio forum + audio member's blogs
lineup |
#7 | |
Sorry man, janneman, but after some re-considering, I suddenly found out that I have the right to remain silent. Anything I say can and will be used against me. So, please, would you dis-regard anything I say beyond this line .................................................. .................................................. .......... your sincere audio friend & not your very clever audio fiend http://lineupaudio.freehostia.com/forum/index.php
lineup |
#8 |
Lineup,
You are more clever than you want to admit! BTW, I am intrigued by your country flag. Are you willing to admit in which country you currently live? Jan Didden
#9 |
yes
no doubt this is one Made in Sweden website like is Volvo Cars, often http://lineupaudio.freehostia.com/ only for non commercial sharing of diy audio knowledge by the one person evrybody now call Lineup All my Regards to Netherlands and to the older nice gentle man called janneman gentle ~ soft and and caring ** Made in Sweden .. reagarding music http://en.wikipedia.org/wiki/Made_In_Sweden_(band) http://en.wikipedia.org/wiki/ABBA ... only a few of our great creative music artists
lineup |
#10 | |
For LTspice users the Yahoo LTSpice Group is the place to be http://tech.groups.yahoo.com/group/LTspice/ If you have one Yahoo Account + Yahoo Mail, like I have, you are logged in automatically and can join this Group ... There is SPICE stuff for Members Only Regards Lineup
lineup |
| New to SPICE | WithTarragon | Pass Labs | 2 | 6th June 2008 06:32 PM |
| Free Spice Or Cheap Spice Simulator-Where To Start? | kelticwizard | Everything Else | 29 | 15th February 2007 01:38 AM |
| looking for spice models | bocka | Parts | 16 | 23rd November 2003 02:00 PM |
| 1- 800- Go- Spice | EternaLightWith | Parts | 9 | 21st May 2003 03:51 AM |
| P-spice THD | JensRasmussen | Solid State | 10 | 18th October 2002 05:18 AM |
| Page generated in 0.13752 seconds (83.64% PHP - 16.36% MySQL) with 10 queries |
