Paralleling power supplies
Old 23rd March 2003, 09:27 PM   #1
thylantyr is offline thylantyr  United States
Default Paralleling power supplies
Found this old thread.
Post #9
http://www.diyaudio.com/forums/showt...hp?threadid=92
Does paralleling three (or more)
power supplies reduce ripple (increase
ripple frequency) ?
What is the pro/con of using
three small power supplies vs.
one large one ?
Old 24th March 2003, 06:18 PM   #2
I seem to stump everyone with my esoteric
questions since joining this forum
or
People fear the evil one, me
or
People think it's a trick question and
wait for someone else to post first
Right now, I'm checking every thread (62 pages)
to gather data for my project, I'm almost done
reading 30 pages of threads. Funny stuff.
I think the Academy award goes to Kilowatt,
the ambitious Jedi Apprentice who builds Tesla
coils, HV squirt guns, and wants to build isolation-less
7kw amplifiers off 240v mains, then only manages
to blow up his 200w Leach amp on the test bench.
!Kudos!
People with monster plans gets my vote for the
award
Old 24th March 2003, 07:01 PM   #3
Jeff R is offline Jeff R  United States
I assume you are wondering about linear supplies.
If so, I would think that paralleling them would lead to more problems than it would solve. I would only recommend paralleling power supplies if you cannot build up a single supply economically. Getting voltages and currents to match and share equally is difficult and typically requires series resistors that waste power.
Unless you power the supply with three phase power, and thus parallel the three supplies from each leg, the ripple frequency will not change by paralleling. The amount of ripple voltage will still depend on the total capacitance and load. Indeed, as unequal currents can be drawn from each paralleled supply, total capacitance will have to be higher, I would guess, than for a single supply.
So, unless you are building one big honking supply where the needed transformer is cost prohibitive, but three smaller transformers that sum up to the same power is cheaper, then I would stick would a single.
Now, that said, using seperate supplies for each channel and even each rail of each channel, for a total of 4 independent supplies, might have some advantages sonically. Indeed, I would recommend this approach instead of paralleling and using that to power the whole amp.
Paralleling power suppliesHide this!Advertise here!
paralleling computer power supply outputs: can they be connected in parallel... jarthel Parts 7 12th December 2012 09:13 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
Paralleling VAS devices for higher power rtarbell Solid State 6 19th November 2005 07:37 PM
Paralleling or Cascading Power Supply Filter capacitors question KevinLee Solid State 4 29th April 2003 12:13 PM
