Hello!
this important schematic is a World Heritage please add your modification Regards
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 |
thanks, Stee
nice schematic ![]() what tests have you done: - as buffer, Gv=1 - at Gv=10 (+20dB) - with different loads - with different input AC levels - with different output AC levels - with different Voltage Supply what is the recommended nominal Power Supply to use? 2 x 20 VDC max ... or what transistors you use - you recommend NPN? PNP? thanks
lineup |
#3 |
Stee
I see you have already this GAS amplifier schematic at your website http://www.esafono.it/hindex_file/image003.jpg http://www.esafono.it/hindex.htm Have you joined my Audio Forum? here it is http://lineupaudio.freehostia.com/forum/index.php very small forum - me as moderator We can post New Project & Discuss your GAS. then later we come back here to www.diyaudio.com and present our result from Project design! =================================== Click my www below my post = audio forum ... easy to join
#4 | |
think is better use power bipolar as 2SA5200 & C TOSHIBA and his drive can be MJE340 & C just to start at Gv=10 (+20dB) with dual 30V do you have a simulator? Regards
#5 |
NFB partition ( 560 and 8K2 )
#6 |
GAS is an ambitious project
to have Class A sound with AB class biasing without bridge and OPA with complementary and balanced criterion in very simply design I have found now a good simulator http://www.catena.uk.com/cgi-bin/download1.pl?id=125930
#7 |
I have installed SIMetrix maybe 2 months ago.
I have not learned how to use. Have we some good transistors in SIMetrix? What we want is simulation software (freeware) with many AUDIO transistors, mosfet and bipolar. People often use these free simulators & schematics designers: - LTspice/SwitcherCAD III http://www.linear.com/designtools/software/ - Eagle CADsoft http://www.cadsoftusa.com/freeware.htm - B2 Spice A/D v4 Lite, which can work with Eagle http://www.beigebag.com/adv4_lite.htm How to build a schematic in Eagle and export it to B2 Spice A/D v4 for simulation: http://www.beigebag.com/eagle.htm Lineup ![]() Lineup Audio Blog & Audio projects Forum for members |
#8 |
I am sure GAS and also UAS will work well.
You do work now. Will later be final versions. Did see you have a nice circuit here (UAS) http://www.diyaudio.com/forums/attac...amp=1219024318 2SJ160 / 2SK1056 as driving 2SC5200 / 2SA1943 ... this is a new idea for me .. but think is not bad Lineup http://lineupaudio.freehostia.com/forum/
lineup |
#9 |
It won't work in real life. Output transistor Ic will be different (because of different beta and different Ib) so one transistor will saturate and stop working.
#10 |
think Giaime is right
| UAS - Universal Amplification Stage | Stee | Solid State | 70 | 12th November 2010 01:23 PM |
| Tubes and Global Warming... | colonelkernel8 | Everything Else | 0 | 2nd April 2008 06:18 AM |
| Multi-stage amplification | sam9 | Solid State | 2 | 5th August 2007 04:49 PM |
| JLH without global feedback? | rmgvs | Solid State | 6 | 10th June 2004 05:10 AM |
| power amplifier with one-stage voltage amplification | alex0 | Solid State | 5 | 7th February 2004 12:02 PM |
| Page generated in 0.15200 seconds (70.09% PHP - 29.91% MySQL) with 11 queries |
