Lost bias on Marantz 1060 right channel
Old 11th November 2009, 03:23 PM   #21
DragonMaster is offline DragonMaster  Canada
Well can you swap the channels on the pre/power amp bridge connectors to see if it's a preamp fault or poweramp?
There could be a lot more than just the output transistors. Dead transistors might give distorted sound, but if it's totally quiet, I'd look at other things first.
Old 14th January 2017, 07:07 PM   #22
Almiscarado is offline Almiscarado  Portugal
Hi there!
It looks like everyone has a 1060 with a dead channel. I got one recently of the big auction site, described as non working.
I have been fiddling a bit, and with a new fuse it is working, left channel is perfect, right channel completely distorted.
I checked and adjusted bias on left channel, but I get no measure of bias on right channel, on any position of the potentiometer.
Nothing looks burned.
Anyone can point me out on what transistors to replace?
I am not very experienced on finding faults, so all help will be helpfull
Old 14th January 2017, 08:45 PM   #23
Now besides distorted, it started doing crackling and popping sounds on the defective channel, wether the balance is torwards it or not
Old 15th January 2017, 02:08 AM   #24
Vinster is offline Vinster  Canada
issues are never the same, you'll have to get the service manual and perform a little investigative work. you're issue does sound similar to the original posters, read through the tread and perform the same measurements to see if yours is the same.
Also having 1 of the 2 channels working, you can also take measurements from one side and compare to the other.
Vin
Lost bias on Marantz 1060 right channelHide this!Advertise here!
marantz 1060 issue pezza89 Solid State 3 29th June 2011 02:02 AM
marantz 1060 transformer naimgame Solid State 3 17th March 2011 10:37 PM
marantz 1060 issue pezza89 Solid State 3 1st June 2008 11:03 AM
Picked up a Marantz 1060. negah Solid State 10 10th December 2007 09:07 PM
Marantz 1060 Blown Left Channel barako Solid State 1 27th July 2007 01:07 PM
Copyright ©1999-2017 diyAudio
