Old 12th August 2008, 01:39 PM   #1
kibet85 is offline kibet85  Kenya
Smile 100 watt audio amplifier
http://english.cxem.net/amplifier/amplifier25.php
Hi all,has anyone done this amplifier....
Old 12th August 2008, 03:07 PM   #2
sakis is offline sakis  Greece
sakis's Avatar
Default this is greek made
from a company called smart kit electronics
if you buy the kit its almost for sure that it will not work since its using bdv 66-67 darligtons that they are not "selected" and i dont mean matched i mean selected ....
bdv 66-67 might have diferent behaviour between company to company and also between the same company but in diferent orders ...
so if in this amplifier you have P and N transitor that they are not complementary your amp is out of balance and bias ( very critikal for this design ) will never work properly
also 100w is overestimated and will never be produced as operating these bdv 66-67 in 40 volts rails and 4 ohms loads is way out of transitors can handle .....
one option will be to get the schematic and part list of this and operate it with MJ15015-16 very nice devices from on semi
but finally you dont expect much of it sound wise no matter what transistors you use
and the best option will be to built a DX amplifier from Destroyer x
( you will get a lot of forum help if you choose to do that ) or other designs the same simple but more safe and effective to built that are discussed here in the forum
simular to DX is the P3 or P3A from rod elliot or sixtec amplifier or symasym and so on ...
search .....you will find plenty
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 12th August 2008, 03:19 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
if looking at the circuit
there is nothing new about it
there is no improvement and good ideas, apart from very rudimentary circuit
It is, in my opinion, a very standard and simple version of Douglas Self blameless amplifier.
And if you want to build one,
I really recommend better you use the information from D. Self website here:
# 0: Introduction.
# 1: The Generic Amplifier Configuration.
# 2: The Eight Distortions.
# 3: Three Non-existent Distortions.
# 4: Techniques for Amplifier Investigation.
# 5: The Distortion Mechanisms.
# 6: The Concept of the Blameless Amplifier.
# 7: Conclusions.
# References.
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm
lineup
Old 12th August 2008, 03:59 PM   #4
sakis's Avatar
Default hei line up ....
the circuit that you are posting looks very nice but in the schematic is normal output transitors
in this particular kit the outs are darligtons BDV 66-67 OR BDW 83-84....
am i missing something ????
Old 12th August 2008, 04:11 PM   #5
lineup's Avatar
Default Re: hei line up ....
the schematic is the very one from topic starter kit!!!!
see link in first post
Now, what output transistors to use, is many choices'
if going darlington we can consider some motorola devices
http://www.onsemi.com/PowerSolutions...s&category=798
Motorola = OnSemi
But the basic circuit is better from D.Self website
This is my basic message to the topic poster.
And good advice.
regards to friend sakis of Grekland = Greece = Hellas = Ella = The Sun
http://en.wikipedia.org/wiki/Hellen
Hellen (Ancient Greek: Ἕλλην, Hellèn)
The word comes from the prefix ??- (el- "sun, bright, shiny", (èlios, "sun")) + ??? (las "rock, stone").
lineup
Old 12th August 2008, 04:48 PM   #6
Default Re: 100 watt audio amplifier
The schematic looks OK.
Conventional Lin-topology solid-state class B/AB amplifier with darlington output stage, with overcurrent & short circuit protection.
The OP stage looks a bit undersized, but for home usage with the inbuilt protection it seems enough.
However for PA usage I'd add one more pair of OP devices. Or change these BDW devices to a 200...250W rated darlington pair.
R2 must be 0.47r/5W, I'm sure that 1r/2W is a misprint.
Solder a resistor in series with P1 for safety reasons! Then I'd double C6 to 220uF.
Rail fuses are needed, use 5A fast-blow fuses /rail.
With the mentioned modifications it's a reliable and cheap project. IMHO it's not that bad as Sakis and Lineup noted. It has a correct PCB design too!
Old 12th August 2008, 04:54 PM   #7
lineup's Avatar
Default Re: Re: 100 watt audio amplifier
Where did I say it was bad, Andy?
please show me the line of my statement
I just said that that the original of D.Self may be worth a look at ....
hehe .. sometimes people make up more than I say
lineup
Old 12th August 2008, 04:59 PM   #8
Some more comments...
P3A hasn't got public PCB design.
P3A hasn't got shortcircuit/overcurrent protection.
DX-amp hasn't got shortcircuit/overcurrent protection.
Symasym hasn't got shortcircuit/overcurrent protection.
Anyway I'm not sure that Kibet85 could find the driver/OP devices in Kenya for DX-amp/Symasym - however this project uses only cheap and easily available parts.
Old 12th August 2008, 05:02 PM   #9
lineup's Avatar
and the kit in question has got what, Andy?
lineup
Old 12th August 2008, 05:02 PM   #10
Default Re: Re: Re: 100 watt audio amplifier
OMG! I need a coffee.
Awfully sorry!!!
High Watt PA Amplifier roots600rr Solid State 24 6th February 2009 05:53 PM
150 WAtt amplifier ali_moinuddin Solid State 9 21st August 2008 01:12 PM
300 Watt Amplifier broka Solid State 1 9th September 2006 07:48 AM
my 60 watt amplifier AAK Solid State 6 15th June 2005 12:59 PM
Page generated in 0.16457 seconds (71.01% PHP - 28.99% MySQL) with 11 queries
