i was reading somewhere that the use of linear pot for volume controls is better than the log .... but there is some resistor that you connect to it to give logarithmic behaviour ......
the think is that i have a bunch of log pots cheap meterial from radioohm or piher and like most of them have audible diference between left and right .... any ideas ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
stereo log pots (dual gang) have a reputation for poor matching between channels. Dual gang lin pots sometimes/often have better matching particularly at high attenuation rates.
That is the only advantage that lin has over log, but for balance of a stereo signal it is quite important. A log faking resistor is usually added to the wiper and ground to simulate the log law over part of the travel. Unfortunately you end up with an S shape law rather than the Log law but it works. A lin pot is usually chosen that is 5 to 10 times higher resistance than the ideal log pot and then a resistor is added that is between 8% and 15% of the lin pot value. It's worth experimenting with resistor value to hear how different values affect the turning of the volume pot. 10k log to 20k log ~= 100k lin + 8k1 to 15k resistor. The output impedance of the lin + faking resistor is higher than the log pot. Take care.
regards Andrew T. |
#3 |
i will give it a try and let you know ....
yet what you said its true ......i took out something like 5 pots out of my stock ....ok they are cheap ...its not the good staff but really and especially in low levels there is audible diference and in all 5 of them thanks andrew
#4 |
There is nothing worse than the stereo image shifting as you alter the volume.
How about connecting a dual gang pot to a low voltage DC supply and putting a DVM across the two wipers. |
#5 |
there is no point to search in all my shop for a cheap but good stetreo log pot.....there must be almost 200 of those in my shop .....
BUT !!!! the first linear alps stero ( cheapest available) lin pot of 100k i found in the shop with a couple of metalfilm 18k sounds a lot better ....there is just a tinny diference in very very low volumes ..... Andrew T is right once more ..... though the log curve is kind of strange not what i am used to from log pots but still is very nice i think also idont know why i thing this pot sounds better than the log any way ( may be its just my idea ) thanks
| 807 E-Linear | Fuling | Tubes / Valves | 51 | 5th April 2011 02:27 AM |
| Linear PS help | ashley_kitty | Power Supplies | 2 | 16th May 2007 01:00 AM |
| Need help with linear PS | tonyptony | Power Supplies | 33 | 14th April 2006 10:37 AM |
| Help with Linear PSU | meta | Parts | 26 | 19th March 2003 04:56 PM |
| Page generated in 0.08418 seconds (77.57% PHP - 22.43% MySQL) with 10 queries |
