These day I have built a single class A power amp, it only work for me, I ready buy a pair FOXTES F200A to it.
It use DC serve, so it don't need the coupling cap, and only have less than 2MV at output port. The gain stage can drive the ZEN, but I love this output stage,it can built a 60W class A amp.But now I only built it output 35W/8R it sound is clear but soft. |
#2 |
#3 |
Interesting circuit. I too use the single ended input configuraion-- sounds wonderful.
Not sure about the servo ? You have a lot of time constants in there. Do you not find they "fight" each other. I use just a single OpAmp and single cap to form the integrator. Makes a nice change to see something a bit different |
#4 |
what output transistors you use?
lineup |
#5 |
Hi!Mooly:
The DC serve work well, I use a dual OPA, the half is a integral amp, it can cut a lot of AC signal, but it will make a bit noise, so I use a 6DB fitter to cut the noise, I ever to made three type DC serve ago, one is this, one is only a intergral amp, one is a intergral amp and a 12DB fitter amp, I like this. If only use a intergral amp, match to this ,you can feel the only a intergral will have a bit "noise" in the music backdrop. |
#6 |
Hi!Lineup:
I use the C5200 only, the gain output stage use MJ11032/MJ11033, I take them work on 60MA , so it don't need extra drive transistor to output stage, If add a drive transistor to output stage, the bass will burly, but I hope this amp have runny of bass. |
#7 |
- MJ11032/33 at 60 mA for voltage amp stage, VAS
- No predriver - 2SC5200 = very good output transistors! - All N-Channel output - Single End Constant Current Class A = Good Output stage amplifier. ---------------------- http://www.audio-gd.com/En%20audio-gd.htm You make very good amplifiers, audio-qd Regards Lineup
lineup |
#8 |
Would you say your amp "sounds" different---better, more musical than other configurations such as LTP input stage etc. |
#9 |
This amp open loop gain is 38DB, -3DB at 110K HZ,
At last, I use the cap of input is 1000P, it -3DB at 55KHZ,close loop gain is 27DB, I don't think wide frequency is better at single output class A, I think , keep the frequency near tube amp, the sound mabey like tube amp. |
#10 |
Single output stage and manostat supply.
| Single Chip Class D | Gerula | Class D | 2 | 13th June 2007 10:09 PM |
| looking for a single channel class D amp module | Thunau | Class D | 9 | 2nd November 2006 03:51 AM |
| class A single ended | darkfenriz | Solid State | 16 | 21st January 2005 07:22 AM |
| Anyone play with the Zen Single-Stage Single-Ended Class A? | Rino odorico | Pass Labs | 13 | 29th August 2002 09:01 AM |
| Page generated in 0.12345 seconds (67.62% PHP - 32.38% MySQL) with 11 queries |
