Old 7th August 2008, 12:08 PM   #1
Default Small signal amp.
Hi all,
I am building an fm receiver based on the TDA7000 chip which will end up having an output of about 75mV. I will be feeding it into the k-502 amplifier, which has an input impedance of 100KOhms and needs 300mV for full output (need 12dB gain?)...So my question is, should I put in a full preamp, or a small signal amplifier? Also, I will be using the LM1310 to demodulte the signal (should I do this after the gain stage? I think i would prefer it
I'd really like to build something that has a low parts count, and I already have a +/- 15V DC power supply that I could use...
Any suggestions?
Thanks,
Byron
Old 7th August 2008, 12:16 PM   #2
AndrewT is online now AndrewT  Scotland
add a line driver stage to the FM tuner output.
It will give the extra gain you require and be capable of driving the capacitance of any following cables/input stage.
It will also ensure you have a consistent low source impedance to present to the next stage.
regards Andrew T.
Old 7th August 2008, 12:46 PM   #3
The aim of my question was to see what kind of line driver stage i should build...I mean, a line stage based on the OPA134 should be fairly simple, or maybe something different?
I mean, there are many different ways to go, but i'd like it as simple as possible.
The +/- 15V power supply i have is for a bugle...i wonder, maybe I could use the parts out of the bugle to build a linestage. I think I was using the OPA2134PA.
B
Old 7th August 2008, 01:03 PM   #4
select a discrete output stage using To92 devices.
there are many to choose from.
From +-15Vdc, you can get around 10Vac into a 10k load and possibly 9Vac into a 1k0 load. Running at 20dB gain and averaging 75mVac output leaves the signal well below clipping, quiet when required and undistorted.
regards Andrew T.
Old 7th August 2008, 02:29 PM   #5
Oh, I thought i'd be able to do a simple gain stage with the OPA2134...looking at the data sheet it should be simple, no?
b
Old 7th August 2008, 03:03 PM   #6
2134, simple yes, reasonable quality yes, but you can do better.
regards Andrew T.
Old 7th August 2008, 04:30 PM   #7
of course, I could try a tube based output stage I suppose...I was just hoping to get away with parts i have on hand already
Seems to me that I only need a couple resistors and the power supply, given what's in the datasheet?
Byron
Old 7th August 2008, 04:35 PM   #8
most tube (valve) output stages have a significantly higher output impedance often around 1kohm, rather than the 50 to 200 ohms that many would suggest.
regards Andrew T.
Old 7th August 2008, 04:50 PM   #9
But the input impedance of the K-502 is ~100K, so I could really go up to about 10K output impedance without issue AFAIK, is that not correct?
B
Old 7th August 2008, 05:23 PM   #10
actually, I remember now that I built a CMOY headamp that has a gain of 11, and a low output impedance, and will run quite happily on my PS...sounds perfect - we'll see how it sounds...if it sucks I will try the discrete path.
Thanks for your help AndrewT!
Byron
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
small signal transistor icko Solid State 13 13th May 2009 01:01 AM
Best small signal BJT for DIY audio? OliverD Parts 1 5th April 2009 04:35 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
best small signal FET? hesener Solid State 22 25th August 2005 03:01 PM
Page generated in 0.14554 seconds (59.04% PHP - 40.96% MySQL) with 11 queries
