Old 6th August 2008, 11:36 PM   #1
Default Speaker switch
I'm just starting to design an A/B speaker switch, that will use a small 8 pin PIC (12F675) and a couple of latching relays, operated by any style of momentary push button switch. It will also provide LED indication of which speaker is selected. I will design a couple of PCBs to suit. Just testing to see if there would be any interest in this project - if so I will get a few more PCBs made at the time.
Old 7th August 2008, 06:04 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Please provide some details like power handling, and how to get PIC source code etc.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 7th August 2008, 06:31 AM   #3
I'm still looking at options for the relays, but would be min 8A switching rating. Going for latching does seem to limit the options available (at least for high quality sealed), and I prefer to use latching in this operation. I was thinking about paralleling 2, but I've gone off this due to concerns if 1 relay fails and doesn't switch over. Although I guess you would notice this (both speakers playing), so maybe it isn't such a big deal and it might be better power handling/quality wise to parallel two. Your thoughts?
Happy to make the source code freely available - there's no rocket science in it - so you can change it as you see fit (eg I'm making it light up 1 or 2 LEDs depending upon which speaker is selected)
Old 7th August 2008, 06:40 AM   #4
Jan Dupont's Avatar
Why latching relays ? You really narrow your choices....
If you want to make something easy to build, go for standard relays (consumption is only 30-40 mA at 24 Volts).
If you go for e.g. FINDER Series 4061 (16A) relays, the special Amplimo (20/100A) speaker relay fitīs in.
www.amplimo.nl
Old 7th August 2008, 06:50 AM   #5
I really wanted to have next to zero power consumption (as these are never turned off) and having 4 relays potentially "on" all the time would be using a constant 4W. I know, it's not much but I would prefer if it was 0.1W (PIC power draw only)
Old 7th August 2008, 06:52 AM   #6
Jan Dupont's Avatar
Do you want two sets of speakers (two relays) connected "activated" at the same time
Edited
Old 7th August 2008, 06:56 AM   #7
No but I would use one relay for the +ve, one for ground for each channel - sorry I wasn't clear
Old 7th August 2008, 06:57 AM   #8
Jan Dupont's Avatar
Why one for ground
Old 7th August 2008, 07:29 AM   #9
I prefer to switch all connections. Just a personal preference. Likewise with preamp input switching.
Old 7th August 2008, 07:49 AM   #10
Jan Dupont's Avatar
That's ok
I agree regarding preamp input switching to prevent crosstalk between inputs, but for speaker outputs I don't see the point....
However good luck with the project
Low tech speaker switch needed clippo Multi-Way 4 30th April 2009 02:43 AM
altering a speaker selection switch ronpilgrim Parts 1 29th April 2009 03:58 PM
Speaker A/B switch Mikerobe Car Audio 4 6th January 2007 07:33 PM
SI Super-T and speaker AB switch to ONE speaker Taperwood Class D 25 24th March 2006 02:08 AM
speaker selector switch blbarth Multi-Way 4 22nd January 2006 01:07 AM
Page generated in 0.12539 seconds (66.68% PHP - 33.32% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
