Class A, push pull amp using transistor - Page 2 - diyAudio
Old 6th August 2008, 06:23 PM   #11
fab is offline fab  Canada
fab's Avatar
Default high bias in push pull
I wonder what Nelson Pass would say about that....
Maybe he should reconsider his F4, F5 and X amps series based on some of you...
I made the experiment on low or no overall feedback design and increasing bias lowered the THD . Unless someone prefers to rely on high NFB as a cure all...
And I am not talking about the overall sound improvement due to class A...
Maybe you should read this article from Nelson "Leaving class A" http://www.diyaudio.com/forums/showt...62#post1553062 and reports your comments...
Or am I missing something here?
Old 6th August 2008, 06:40 PM   #12
Mooly's Avatar
I am sure Nelsons designs do "what they say on the tin" and don't suffer from compromised layout, wiring and design flaws. Unfortunately many commercial products do to say nothing of D.I.Y. projects, and upping the the current won't neccessarily improve matters, it can make things worse in some cases.
Old 7th August 2008, 09:23 AM   #13
thanks to Zen mod,
i find "Krell KSA50" is nice for me. will it be easy to build? i don't need to much watts, 50 is more then enough for me as class A amp.
i am reading more about "Krell KSA50"...
i am worried that anythings goes wornd it could triger to class AB.
thank you.
Old 7th August 2008, 10:04 AM   #14
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
Just got a Marantz PM7200. It has a class A switch for quick comparison with class B mode. The difference between classA and classB is too little to be noticeble IMO, probably because the high NFB already reduces much of the distortion even in class B mode. So, increases the biasing doesn't always gurantee better sound. The overall design of the amp itself is more important.
Old 7th August 2008, 10:10 AM   #15
KSA50 is a push pull ClassA amplifier, 50W into 8r0.
It will automatically go into ClassB if you demand more than ClassA current from it, eg. 100W into 4r0.
The normal ClassA bias is 1.9A. The maximum ClassA output current is~3.8Apk.
The 2pair MJ15003/4 output stage can survive 2ohm loading, putting out peak currents of the order of 20Apk, way in excess of the ClassA maximum current. The transient peak current capability is probably of the order of 40Apk.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th August 2008, 10:26 AM   #16
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default I did discuss, before
Can I change Bias?
Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 7th August 2008, 03:38 PM   #17
fab's Avatar
It will automatically go into ClassB if you demand more than ClassA current from it, eg. 100W into 4r0....
Good reminder AndrewT that class A power is dependent of load impedance. And a speaker impedance varies a lot depending of the frequency of the signal...
Old 7th August 2008, 03:41 PM   #18
fab's Avatar
I can hardly understand how a bias switch can do a good job here. The thermal balance of the same whole amp will be different between 2 bias settings. This can be one reason (as many others like the conditions of the sound test done) why it does not sound different or better. It may even sound worse at high bias if thermal balance is modified. On my side, choosing the bias is done at the early stage of the design...
One can not simply take any completed amp and increase the bias with eyes closed. The conditions when the amp goes from class A to B must be carefully analysed. But, as long as the sound stays in class A power level then there is no output transistors switching artefacts thus there should be one problem to be put aside...
Old 7th August 2008, 03:53 PM   #19
fab's Avatar
Default Re: Sorry to butt in
Originally posted by mikee55
...how do you know if you're in Class A anyway? An Led indicator type circuit would be nice.
Mike
I have one installed in one of my amp. Its my own design and it may not be perfect (depending on dynamic variation of DC offset at output and filtration of the very low frequency) but it gives a good idea.
See http://www.diyaudio.com/forums/showt...051#post703051
It should work in follower power amp output stage but not verified if other topology would...
2A3s in push pull; class A Sir Trefor Tubes / Valves 44 31st May 2013 04:37 AM
40W class A push pull amp with JJ 2A3-40w possible? 3nity Tubes / Valves 18 27th May 2010 12:05 AM
Class A push-pull Nikolas Ojala Pass Labs 5 24th August 2009 01:58 PM
Class A Push Pull with 6L6GC d1camero Tubes / Valves 9 4th December 2007 09:35 PM
EL34 Push Pull in Class A arnoldc Tubes / Valves 29 17th May 2006 12:52 PM
Copyright 1999-2017 diyAudio
