my new ampli mosfet
my new ampli mosfet
Old 5th August 2008, 12:53 PM   #1
xcicc is offline xcicc  Italy
xcicc's Avatar
Default my new ampli mosfet
Hi, I try to make this ampli any suggestion?
regard
A.
Old 5th August 2008, 01:25 PM   #2
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Check out current sources and polarity of P-fet.
Old 5th August 2008, 03:07 PM   #3
xcicc's Avatar
Hi made some change the polarity on P-fet and I add the voltage...
A.
Old 5th August 2008, 03:35 PM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
my new ampli mosfet
I think the output bias scheme will give you problems due to wide tolerance of Vgs. Also I think there is massively insufficient drive to the output MOSFETs.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 5th August 2008, 03:43 PM   #5
fab is offline fab  Canada
fab's Avatar
Default triac?
Is there a triac between the amp output and input of drive of mosfet2? if so, what is its purpose. Is it a protection and how is it suppose to work?
Old 5th August 2008, 08:30 PM   #6
xcicc's Avatar
Default Re: triac?
Hi, yes the purpose of this triac is for short circuit protection.
why? is useless??
A.
Old 5th August 2008, 08:44 PM   #7
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
my new ampli mosfet
You are still forgetting about powering of left upper current sources.
The Devil is not so terrible as his math model is!
Old 6th August 2008, 02:11 AM   #8
fab's Avatar
He's right. At least a resistor should be put from the diodes-transistors base connection point to either ground or negative power rail.
Old 6th August 2008, 05:36 AM   #9
xcicc's Avatar
Hi, you mind this? I made some correction I hope is right...
Old 6th August 2008, 05:56 AM   #10
lineup is offline lineup  Sweden
lineup's Avatar
Latest attachment.
http://www.diyaudio.com/forums/attac...amp=1218000976
It might work.
But personally I woul use a little bit more current to bias the GATES of IRFP140/9140
28Volt/100kohm ~ 0.3 mA
Make those 100 kohm resistors ~27 kohm .. or even 10 kohm
Would give: ~ 1 - 3 mA
Also I would connect those bias resistors ( 100kohm / 27 kohm )
BEFORE those gate stoppers ( 47 Ohm resistors ).
If you change from 100 kohm .. to 27 kohm,
then you should make those 47 kohm (in parallel with 4.7uF) smaller, too.
Maybe like 4k7.
And those two (now 47 kohm) should be connected to GROUND.
To try and keep, hold, the output MOSFETs at zero DC Offset.
The point between those two resistors, I mean, should be connected to GND.
lineup
my new ampli mosfetHide this!Advertise here!
use a PA ampli for sub cld1354 Multi-Way 29 29th June 2009 09:39 AM
ampli mosfet irf 540 + irf9540 xcicc Solid State 24 20th March 2009 12:10 AM
ampli mosfet with irf530/9530 ciccio9000 Solid State 17 10th June 2007 10:41 PM
My Ampli Pollix Solid State 9 9th February 2004 09:50 AM
Copyright ©1999-2017 diyAudio
