What are the popular heatsink suppliers,
low cost to high cost, simple to exotic heatsinks for high powered amplifiers? I wanted to make a list of common dimensions from these heatsinks so I can try to figure out what PCB board dimensions to use for the Aussie Amplifier AV800 project. What I'm trying to figure out is ....... If I do printed circuit layout on CAD, would it be best to make the board dimensions compatible for various types of heatsinks depending on what power level you plan to operate the amplifier? I want a flexible pcb design that allows small, medium, or large heatsinks depending on application, perhaps mounting the pcb directly on the heatsink with standoffs and the transistors clamped to a strip of metal that is also mounted on the heatsink. similar to what the home audio folks do with their multichannel amplfiiers, where each channel is a module. Or.... Should I abandon this idea and just mount "whatever" pcb on a 1/4" aluminum plate, then mount "whatever" heatsink on the plate ? |
#2 |
check this out
![]() BIG heatsinks source!! I bought 2 boxes of heatsinks...6 sinks total. Each is 19x15x1.5" and is rated at about .2C/W :-D Check it out! The heatsinks are GORGEOUS!! -Matthew K. Olson |
| PCB Suppliers (for UK) | richie00boy | Parts | 1 | 5th March 2007 12:57 PM |
| very large/huge heatsink suppliers in Australia | mastertech | Solid State | 6 | 13th November 2005 12:01 PM |
| Heatsink dimensions | sobazz | Solid State | 9 | 26th January 2004 10:37 PM |
