Blind Listening Tests & Amplifiers
Closed Thread
Old 24th May 2003, 04:36 PM   #1271
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Blind Listening Tests & Amplifiers Send a message via AIM to Peter Daniel
Default Re: Re: Re: I Find All Of It Interesting....
Originally posted by Circlotron
Finally! Something I can agree with.
On the other hand, what about the several tens of metres of wire *after* the power cord that the power tranny is wound from? Isn't that going to undo any effect of a 2 metre length of magic power cord? Or is that like the long length of woofer crossover choke wire not being able to undo the effect of miracle speaker cables?
Not neccessarily. Your wall outlet is your reference, and you can't do nothing about it. Anything you attach to it, will pose it's own sonic signature, you like it or not.
Some are less fortunate and have several tens of meters from power transformers, some others have transformer right across the street, with 10 meter of custom wire connected to it and custom wire in a wall. Again, you may like it or not.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th May 2003, 04:36 PM   #1272
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Default Re: THEORY & REALITY.
Originally posted by fdegrove
Yep...one thing people often forget is that speakers change impedance with frequency.
But what has this to do with "there is much more going on than is explained by standard LCR theory"? A speaker's changing impedance with frequency is explained by standard LCR theory.
se
Old 24th May 2003, 05:13 PM   #1273
Steve Eddy's Avatar
Originally posted by nania
Forgive the slightly off topic post but did you ever do a blind listening test of two comparatively identical preamps/amp with battery vs. mains supply?
Nope. Haven't any interest in doing blind testing. I just go with whatever works for me at the subjective level.
I ask this because your insight and suggestions may be very helpful in the "Fly me to the moon:6181/inverted gainclone" thread. I think I remember you being a proponent of battery supplies, am I mistaken?
Batteries have worked well for me, yes. But that's just my subjective experience so take it for what it's worth.
se
Old 24th May 2003, 05:16 PM   #1274
Steve Eddy's Avatar
Default Re: Re: Re: Re: I Find All Of It Interesting....
Wanna bet?
se
Old 24th May 2003, 05:44 PM   #1275
Unless you want to go into a serious remodelling.
www.audiosector.com
Old 24th May 2003, 06:11 PM   #1276
Steve Eddy's Avatar
Naaaaah. Just a simple *snip* *snip*. Problem solved.
se
Old 24th May 2003, 06:21 PM   #1277
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Battery Supply?
Frank
Old 24th May 2003, 07:19 PM   #1278
Steve Eddy's Avatar
Battery Supply?
Naaah. Flux Capacitor. 1.21 Gigawatts, baby!
se
Old 26th May 2003, 09:47 AM   #1279
carlosfm is offline carlosfm  Portugal
Banned
Talking Cables and cables...
There are many cable topologies, and no one is perfect.
As you may know, a perfect cable would have very low impedance, inductance and capacitance.
Unfortunately it's impossible to have the three at the same time.
If you have a low inductance cable, it will have high capacitance.
A given speaker cable may give excelent results with amplifier A a very poor with amp B.
That's why you really have to test the cables with your gear.
You can put the best speaker cables in your Naim amp an run into trouble.
That's why Naim sells speaker cables.
And they're nothing special.
But they give the best results with their amps.
DNM is the same story.
So, don't jump into conclusions by measuring.
One amp may react better to high capacitance, others may not.
The same for inductance.
As for mains cables, it's good to have a good shielding (it can't be bad).
As for differences, I think that in countries where you have 110 volt mains you may notice more differences than in Europe.
110 volts has double the current and your big amp won't like bellwire for mains.
Old 27th May 2003, 10:38 PM   #1280
Christopher is offline Christopher  Canada
Christopher's Avatar
Default put your hands where I can see them and step away from the paddles!
Nobody is spanking anybody today. A little thing called context is in order here.
You know I shouldn't give these guys any ideas, but, the next thing they'll be doing is seeding all the nervous audiophiles with the idea that cables degrade over time, and no matter how good they were when you bought them, if they've been used alot, at high volumes, they probably should be replaced. "just take a new pair home and compare them to your old ones, you'll be amazed"
Two things here, firstly I never said they did not degrade over time I said seeding them with the idea that they do. Like telling someone that skin effect changes the properties of the cable. At what frequency? Secondly I inferred [i]wear[\i] of the cable, "used a lot at high volumes". Now unless you've got a lot of DC offset in your hi-end gear...
Brace yourself, I can come up with at least another dozen of reasons why cable can sound/interact differently other than the factors you seem to hold as important Chris...
Well Frank, it's not me, it's the whole physics community in general. L,C,R nothing else. Any effects (including skin effect and the likes) changes one of those three parameters. If it does not, then I'm afraid it cannot effect the sound, as it cannot effect the signal. I will state this once more for fun, if a difference can be heard, it can be measured, in an anechoic chamber, and at the speaker terminals. That's how we've gotten as far as we have in audio engineering.
Chris
Closed Thread
Blind Listening Tests & AmplifiersHide this!Advertise here!
