Closed Thread
Old 24th May 2003, 05:27 AM   #1261
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by mrfeedback
Hi Peter, I agree with pretty much all of what Mike VansEvers has to say - I went down that track a long time ago.
Eric.
I've been walking that path quite recently actually (about 2 years) but whatever I read there is much in line with my own findings and experimentation. Since I experienced it, I always keep an open mind and even if something seems hard to believe, I will never question or criticize, untill I try it myself.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th May 2003, 06:17 AM   #1262
mrfeedback's Avatar
Default I Find All Of It Interesting....
Yes, I have turned up many things that at the time seemed weird or 'impossible', but now are old hat to me.
Keeping an open mind also allows better hearing, and this whole process has led to the cables that I refer to.
There is much more going on than is explained by standard LCR theory.
Eric.
I believe not to believe in any fixed belief system.
Old 24th May 2003, 07:36 AM   #1263
Steve Eddy's Avatar
Default Re: I Find All Of It Interesting....
And there is much much more going on still. Namely human physiology and psychology. And anyone in denial of that should refrain from claiming to have an open mind.
se
Old 24th May 2003, 10:41 AM   #1264
Circlotron's Avatar
Default Re: Re: I Find All Of It Interesting....
Finally! Something I can agree with.
On the other hand, what about the several tens of metres of wire *after* the power cord that the power tranny is wound from? Isn't that going to undo any effect of a 2 metre length of magic power cord? Or is that like the long length of woofer crossover choke wire not being able to undo the effect of miracle speaker cables?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 24th May 2003, 10:42 AM   #1265
mrfeedback's Avatar
Default To Steve.
You just can't let go of the psychology BS can you.
See my above posts about no prior knowlege of usage of my cables.
Jeezus, talk about dogmatic beliefs.
Eric.
Old 24th May 2003, 10:52 AM   #1266
mrfeedback's Avatar
Default To Graham
Fred gave a very good explanation of loading effecting stages the other day.
This is a good explanation for some sonic changes due to changes in cable types.
Eric.
Old 24th May 2003, 04:24 PM   #1267
Steve Eddy's Avatar
Default Re: To Steve.
Yes, I can't let go of the psychology BS. Just like I can't let go of the germ theory BS, the sun-centric solar system BS. The spherical earth BS, etc.
Why? I don't recall saying anything about your cables.
Excuse me? How does keeping one's mind open to all possibilities constitute dogmatic beliefs?
se
Old 24th May 2003, 04:29 PM   #1268
Send a message via AIM to nania
Steve Eddy
Forgive the slightly off topic post but did you ever do a blind listening test of two comparatively identical preamps/amp with battery vs. mains supply? I ask this because your insight and suggestions may be very helpful in the "Fly me to the moon:6181/inverted gainclone" thread. I think I remember you being a proponent of battery supplies, am I mistaken?
Old 24th May 2003, 04:30 PM   #1269
diyAudio Senior Member
fdegrove's Avatar
Default THEORY & REALITY.
Yep...one thing people often forget is that speakers change impedance with frequency.
And that's just one thing.
Frank
Old 24th May 2003, 04:31 PM   #1270
Steve Eddy's Avatar
Default Re: Re: Re: I Find All Of It Interesting....
Dunno. My only point was that those in denial of certain realities shouldn't speak of having open minds. Nor should they accuse others of having closed minds.
se
Closed Thread
Page generated in 0.12452 seconds (81.35% PHP - 18.65% MySQL) with 11 queries
