Hi All!
I have a BGW 750C that I'd like to recycle into a nice DIY amp. I would prefer a powerful 200-300WPC amp. A nice Class A would be fine but the transformer voltage is too high I believe. And I would like something to power my Carver Amazings anyways.
I have looked at a few threads, but there is so much information I've been overloaded.
The transformer appears to be able to operate at +/- 70 volts. Not sure of the current, I'm ***uming 7-8 amps into 8 ohms.
I can repair this amp easily enough. But I'd like something of quality. I am using two Sony TA-N77ES amps right now bridged.
Thanks!
Thanks!
thats a good super heavy duty transformer perfect for making a 200watt pch amp. the bigger issue was the heatsinks on those. there isn't much of a sink if i remember correctly for that big of an amp. and definitely not for class! 100 wpch class A maybe before the Temp gets too high.
Zc
Zc
Invalid Request
It's designed to drive a MOSFET output stage but can drive BJT too. Check the datasheet.
