Crown D150A Problems
Old 28th July 2008, 10:44 PM   #1
hmontgomery is offline hmontgomery  United States
Default Crown D150A Problems
As a learning project, I have taken on repairing a Crown D150A (before IOC) Amplifier. Symptoms are Channel 1 is distorted, channel 2 sounds fine. using a Tektronix T922 and Heathkit IG-18 signal generator, 8 Ohm dummy load, I find the top half of the sine wave on channel 1 is missing. Channel 2 looks fine up to the rated output of 80 Watts. + and - 45 Volt supply voltages are at about 42-43 volts and 33VAC supply is attached to the board. I measured the signal coming directly from the op amp and again ch. 2 is a nice sine wave, ch. 1 is missing the top half. I measured the voltages on each pin of the op amp and get the following:
1 8.94v 14 9.78 v
2 9.8 v 13 1.08v
3 6.46v 12 9.04v
4 6.26v 11 6.39v
5 -0.1mV 10 6.38v
6 -5.3mV 9 -0.1mV
7 -9.62v 8 0v
The chip is the UA739PC
Any thoughts?
Thanks.
Old 29th July 2008, 01:34 AM   #2
djk is offline djk
R.I.P
djk's Avatar
http://www.crownaudio.com/pdf/legacy...nual_part2.zip
See pg.14
Candidates for the Darwin Award should not read this author.
Old 29th July 2008, 11:41 PM   #3
Thanks for your reply. I have thet service manual and have gone down the list. Replaced the mentioned caps, diodes check fine. Not real sure how to verify the transisters in circuit and was hoping the voltages on the IC may point me in a direction without removing the transisters to check.
Old 30th July 2008, 01:55 AM   #4
djk is offline djk
R.I.P
djk's Avatar
The IC is probably bad.
I would just replace the IC, and Q102, and Q202 in the good channel (these transistors frequently fail).
Old 30th July 2008, 06:52 AM   #5
Thanks again for your help. That sounds like a plan.
Howard
Old 12th August 2008, 11:44 PM   #6
Replaced Q102 and it fixed the problem. Replaced Q202 as well. I bought three of the IC's but ebded up not needing them. Thanks for your help.
Old 8th September 2015, 07:07 AM   #7
djk is offline djk
R.I.P
djk's Avatar
http://adn.harmanpro.com/site_elemen...2_original.zip
New URL, consider replacing C4, C5 as well.
Old 10th September 2015, 08:30 PM   #8
dogdays is offline dogdays  United States
I have a few D150As and am wondering if there is a substitute op-amp that would sound better?
Also are Fairchilds better than others?
Thanks,
R.
Old 13th September 2015, 09:30 AM   #9
djk is offline djk
R.I.P
djk's Avatar
I am not aware of a drop-in replacement for the ľA739.
Perhaps someone else can suggest?
Crown D150A ProblemsHide this!Advertise here!
Crown sa 20 Newpaltzwonder Solid State 5 25th May 2011 10:12 AM
crown xls 602 amp galush Solid State 0 6th April 2009 04:41 PM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 04:24 AM
JBL Crown BPX1100.1 problems shagone Car Audio 13 2nd May 2008 10:56 PM
crown d150a khelben Solid State 19 5th June 2005 11:56 PM
