Old 29th July 2008, 07:19 AM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally posted by phase_accurate
The distortion mechanisms of speakers and amps are quite different.
And they are perceived different. So the higher speaker THD is still less objectionable than the amp's nonlinear distortion.
Earl Gedds has a nice paper on that.
Does somebody need any paper to understand that we are surrounded by so called "mechanical distortions" the whole our life; we sing, cry, communicate using them, we play music using mechanical oscillating system that generate such "distortions", but we don't perceive them as distortions. We perceive them as sounds and when level of such "distortions" change we perceive as changed loudness
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 29th July 2008, 08:20 AM   #12
I boldly claim that it isn't the origin as such (i.e. mechanical or electrical) that causes the differences in perception.
It is how the nonlinearities behave. If a "mechanical distortion" is made to behave like amplifier crossover distortion for instance it will be perceived the same way I claim.
Charles
Old 29th July 2008, 09:02 AM   #13
Wavebourn's Avatar
Hmmm... Can you describe a model of such a mechanical device?
Old 29th July 2008, 10:18 AM   #14
traderbam's Avatar
Default Re: Re: Re: GNFB and distortion
Originally posted by myhrrhleine
Given otherwise identical zero-GNFB amps, I prefer the lower distortion amp.
I strive to reduce distortions with other means than GNFB because I really don't want the distortion.
How about you?.
Me too. Any distortion is undesirable in principle. But it depends on the type of distortion. Our brains are very choosy about the specific mix not just the total. It is a bit like judging the impact of noise pollution based on total amplitude rather than specific noises. For this reason, amongst others, THD+N is not an effective parameter to compare sound quality between amps or speakers.
Also, when two amps have the same total distortion, any two people might have different preferences of the mix. When modest distortion is present there may be disagreement about which amp plays music better. Only when all audible distortion is eliminated will there be a good chance of agreement.
Old 29th July 2008, 10:57 AM   #15
Not at the moment but maybe I will stumble upon one.
The difference in perception is not coming from the fact that one is natural and the other isn't IMO.
HOW they influence a signal is what matters IMO. Just imagine that a nonlinearity around the zero crossing will influence almost any signal and the weakest even the most.
Whereas 2nd and 2rd order distortion from a speaker is almost absent for really weak signals and is rising with level. It is influencing signals of high amplitude (where the ear is also far from linear) but leaves weak signals (and fine details) almost untouched.
Charles
Old 29th July 2008, 11:06 AM   #16
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
How about you ?
I like New York in June.
How about you?
I like a Gershwin tune.
How about you?
I like a fireside when a storm is due.
How about you?
I like potato chips, moonlight, and motor trips.
How about you?
Not so much,.......if it says "ZM" in the corner.
Old 29th July 2008, 05:55 PM   #17
myhrrhleine's Avatar
Originally posted by lineup:
No, actually, no
For Pavel Macura maybe
But not for one listener.
I explain:
- Tube amplifiers are know to distotion producers.
- Loudspeakers are REALLY distortion producers. Does not matter what power amplifier you use.
Valve power or Solid State power or MOSFET power.
No big difference for our loudspeaker part.
It will produce considerably more distortion than any modern amplifier.
von Schweikert are expensive High End audiophile speakers
no doubt about this
Still von Schweikert has a level of 0.5% THD at 1-2 Watt RMS.
1 meter away from speaker on axis.
PMA talks about the -90 dB level. He is in his dreams
Because when listen with loudspeaker
and consider the Listening Room effects
( floor and ceiling and walls indirect sounds )
we are close to 1 % THD at 1 Watt.
1% = -40dB
0.0032 % = -90dB
What will dominate what we hear?
the Op-Amp THD or the Speaker THD.
I do not know what you think is correct answer.
But fortunately still I have some intact logics in my brains.
I attach the THD test curve of von Schweikert very expensive speakers.
They are NOT low or ordinary quality as of yours and mine speaker systems.
And they try to avoid Room influencis when measure
by putting Test Microphone 1 meter on Axis in front of speakers baffle.
so, you *like* distortion?
Personally, I do not.
My original post said
Do you truly like 2nd harmonic or third harmonic distortion?
Not me.
Just because you can't hear it doesn't mean no one can.
Suitable jfet for an zero GNFB amp? roender Solid State 14 28th November 2008 04:08 PM
distortion with LPs Zero One Analog Line Level 19 23rd August 2006 07:09 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
The look of distortion. Joel Tubes / Valves 3 26th June 2003 10:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
