Old 28th July 2008, 05:29 PM   #1
Default Mosfet amp or Transistor amp?
which one is good..? in terms of transparency? I think Mosfet amps are good enough but I would like to know why Brystons use Transistors?
Old 28th July 2008, 08:24 PM   #2
Stee is offline Stee  Italy
Stee's Avatar
Default better way toghether
ciao
my idea is swap the standard hybrid
with transistor in input/VAS + mosfet as final
using
2SK170 AND 2SJ74 for input/VAS
MJE15030 AND MJE15031 (8A-50W) AS FINAL STAGE
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 28th July 2008, 08:30 PM   #3
kalmara is offline kalmara  Bulgaria
kalmara's Avatar
You know ... mosfets are also transistors...
Insane HONDA FAN !!! Variable Valve Timing and Lift Electronic Control equals....HIGH ADRENALINE !
Old 28th July 2008, 08:53 PM   #4
annex666's Avatar
I think the terms you are looking for are:
Unipolar transistors (field effect devices)
Bipolar transistors (junction devices)
...if it ain't broke don't fix it - make it BETTER!
Old 28th July 2008, 09:46 PM   #5
nigelwright7557's Avatar
Default Re: Mosfet amp or Transistor amp?
Both are good for amplifiers.
I have built my own using both and had very good results.
Personally I would stick to a tried and tested design.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 29th July 2008, 11:35 AM   #6
AndrewT is online now AndrewT  Scotland
Default Re: Re: Mosfet amp or Transistor amp?
Yes, both BJTs and FETs can give very good results in a good design, but both are capable of very poor results in a bad design.
regards Andrew T.
Old 29th July 2008, 04:56 PM   #7
Stee's Avatar
Default fet mosfet and bipolar
start with fet on input 2SK170/2SJ74 are very good
then for voltage gain stage better use 2 big mosfet like 2SK1058/2SJ56
For final stage are better bipolar 2SC5200/2SA1943
Complementary configuration is essential for ideal results
the architecture is traditional but without second current stage
sorry don't have good picture
Old 29th July 2008, 05:01 PM   #8
Stee,
the second stage (VAS) uses jFETs in your posted schematic, not big mosFETs.
The capacitance of a 1058 would kill the mid and treble response of the LTP stage.
regards Andrew T.
Old 29th July 2008, 05:48 PM   #9
Stee's Avatar
Default see now
thanks
may be is better using a little mosfet like IRF610
or IRFD110?
another idea is a paralleling of 2SK170/2SJ74 (3/4 times)
as VAS...
Old 29th July 2008, 10:03 PM   #10
Stee's Avatar
Default also this is intresting
but need a reverse configuration... to be modern
fet are good for input
mosfet for tension
bipolar for current
(may be)
really final stage have voltage gain too (Drain in common)
Help me find a Mosfet/Transistor amp project useing what I have available?? Minion Solid State 11 9th May 2007 04:30 AM
Transistor and MOSFET recommendations? meretrix Parts 2 24th January 2005 11:45 AM
Audio MOSFET transistor Hisatugo Solid State 2 11th August 2003 08:41 AM
Transistor / MOSFET Questions... Solid Snake Solid State 4 27th February 2003 08:05 PM
Is this MOSFET transistor? Mikka Solid State 5 3rd February 2003 07:07 AM
Page generated in 0.19326 seconds (44.69% PHP - 55.31% MySQL) with 11 queries
