push pull Vs single ended class A amp - Page 3 - diyAudio
Old 6th August 2008, 10:02 AM   #21
Default parallel output pairs
1pair using Re=0r11 gives 0.6W of power before entering ClassB.
2pair gives 2.5W while still in the ClassA region.
3pair gives 5.5W in ClassA.
4pair gives 10W in ClassA.
But, I prefer to increase output Re as the number of parallel pairs increases bring the ClassA limit back doown.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th August 2008, 10:07 AM   #22
roender is offline roender  Romania
roender's Avatar
Default Re: parallel output pairs
Are you shure, RMS power in 8 ohm?
Old 6th August 2008, 04:54 PM   #23
Vre=20mV, Ire=200mA, IpkclassA=400mA, PclassA=0.4^2*8/2=0.6W
2pair runs double the current and gives four times the ClassA power.
3pair runs triple the current and gives nine times the ClassA power.
regards Andrew T.
Old 7th August 2008, 05:49 AM   #24
roender's Avatar
P=I^2*R
P=Irms*Irms*R
Irms=Ipk/sqrt(2)
P=Ipk^2*R/2
Ipk=Ipp/2
Andrew, please make the math again.
Old 7th August 2008, 08:46 AM   #25
why?
Your formulae agree with mine and on the 0.6W we agree as well.
regards Andrew T.
Old 23rd August 2008, 04:31 PM   #26
vizion is offline vizion  United States
Is the difference between SS single ended and push pull similar to the difference between a tube single ended and pull ? Like an EL84 tube, music would sound different when used in an SET for 1.3w vs. a triode push pull model. That's for starters then you play in directly heated thoriated triodes like the 845 and such.
Single-ended OR push-pull? kacernator Tubes / Valves 48 31st March 2008 03:50 PM
Single ended amp from class A push-pull Wavebourn Tubes / Valves 2 12th October 2007 10:14 PM
Is single ended Class A better than push-pull? okhifi Tubes / Valves 49 1st September 2005 08:26 PM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 07:04 AM
Copyright 1999-2017 diyAudio
