I find the power supply capacitors highlighted in attached file are abnornmally hot. Can anyone advise the problem please?
#2 |
May be just the caps themselves failing, having developed a high E.S.R. They look highly stressed ripple current wise, try replacing with suitable new ones. The plug/socket to the diode bridge isn't open circuit is it. These limit the max voltage across the caps.
Probably just the caps themselves |
#3 |
Thanks your advice. Actually I replaced new capacitors with same specification but there is no improvement. I don't know what happen.
#4 |
The polarity of the two caps look wrong on the schematic.
Try nonpolarity caps there. |
#5 | |
#6 | |
check the max Voltage rating of those caps. The other thing is CHECK the polarity. see to that they are not put the wrong way! Because if, this is certainly a big problem ... Correct is: - cap + .... resistor .... + cap - if we are to believe in your schematic Third, as capacitors normally do not get very hot: Have a look if actually it is caps that produce heat. Maybe it is some resistor? Close to those caps.
lineup |
#7 |
Do C101 and C102 not get hot?
BR3 is probably damaged. |
#8 |
a shorted diode in the bridge rectifier would have been my first choice until i looked closer at the schematic. the bridge rectifiers are actually connected as voltage limiters here. very strange, but the caps are probably hot because a diode in the bridge is open. these are very low voltage caps, and the bridge rectifiers limit the voltage across the caps to about 2v (+/- a sizeable fudge factor of about .8V)
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#9 |
Thanks for your all advices. I measured the voltage across R106 and it was about 0.8V. Is the BR3 health?
On the other hand, the C101 and C102 are not hot. They are okay. |
#10 |
Dare we even ask what it is
| Power supply problem | Niila | Tubes / Valves | 6 | 12th April 2008 01:39 AM |
| Power supply problem | krzanik | Tubes / Valves | 19 | 1st May 2007 03:56 PM |
| problem with LM's and power supply | KostasTheGreat | Chip Amps | 14 | 10th March 2005 02:13 PM |
| Power supply problem | PassFan | Tubes / Valves | 6 | 24th October 2003 10:03 PM |
| Power supply problem (or something) | ir | Chip Amps | 4 | 23rd August 2003 08:44 AM |
| Page generated in 0.18339 seconds (47.05% PHP - 52.95% MySQL) with 11 queries |
