power
power
Old 20th March 2003, 11:40 AM   #1
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
Default power
how much power RMS can i get from bridge amp
with 50V+- 1200VA in 4 - 2 ohm ...?
Old 20th March 2003, 01:30 PM   #2
Account Disabled
ok....... so i will go to another site - forum....
Old 20th March 2003, 02:10 PM   #3
Dirk is offline Dirk  Belgium
If you know Ohm's law, you can easily calculate this yourself :-)
Dirk
Old 20th March 2003, 02:48 PM   #4
HDTVman is offline HDTVman  United States
Default Re: power
DJ, not enough information here for anyone to accurately calculate the power. You have given us the power supply voltage and transformer rating but these don't tell us anything about what the amplifer output rating mignt be. That is what is needed here.
Later
BZ
What ever makes the tunes flow
Old 20th March 2003, 05:25 PM   #5
e96mlo is offline e96mlo  Sweden
DJ, you will try to draw more power than the transformer can deliver: 1250 Wrms @ 4 Ohm. This is a theoretical figure and will be less in practice.
May I also point out that it is ridiculous of you to expect an answer within the hour!
HDTVman, it is true that an entirely accurate figure cannot be obtained but a maximum theoretical figure can.
/Marcus
Old 20th March 2003, 05:57 PM   #6
Fred Dieckmann is offline Fred Dieckmann  United States
diyAudio Retiree
Default Please..... don't go!
I, for one, would miss your insightful and thought provoking queries.....
Old 20th March 2003, 06:53 PM   #7
Account Disabled
what the formula to now Watts with ohm ?
Old 20th March 2003, 06:58 PM   #8
Check out www.sound.au.com where the articles for beginners probably would suite you. They are well written and are primarily covering audio.
Otherwise borrow a book on basic electronics from your school.
/Marcus
Old 20th March 2003, 07:41 PM   #9
Samuel Jayaraj is offline Samuel Jayaraj  India
Fred, is this supposed to be a joke?
This guy has a long way to go before he learns the basics of PA equipment.
Sam
Old 20th March 2003, 07:56 PM   #10
Fred, is this supposed to be a joke?.
Let's see, my guess would be yes.
powerHide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Copyright ©1999-2017 diyAudio
