I saw this circuit in the datasheet of the PAD126, released by Power Amp Design (www.powerampdesign.net). I have reproduced a version of it in PSPICE to make this included picture. I was curious as to why each output transistor has both an NPN and a PNP driving its gate (for a total of four driver transistors instead of two).
Q2 is the common emitter, and Q1 is the current source/active load. There is a vbe multiplier (Q7), and the output transistors are M1 and M2. For a cleaner schematic, I skipped two connections. Assume that the collector of Q5 is tied to the minus rail, and the collector of Q4 is tied to the plus rail. I am assuming that the driver stage (between VAS and output stages) is composed of Q3, Q4, Q5, and Q6. --> Why does each output transistor have both an NPN and a PNP driver? I have never seen this before with the "extra" transistors (the PNP Q5 for the N-type output transistor, and the NPN Q4 for the P-type output transistor). |
#2 |
diyAudio Moderator Emeritus
Q3-Q5, Q4-Q6 forms a totem pole, a low impedance for driving mosfet gate. Usually we can see this in switching stage, but some AB amps use this driver configuration too.
| Need help understanding differential input stage | Bitrex | Solid State | 5 | 14th June 2009 04:51 AM |
| Understanding output stage SOA?? | Zero Cool | Solid State | 8 | 22nd November 2007 10:57 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 12:14 PM |
| What should I do with extra transistors? | random_id | Chip Amps | 2 | 11th April 2005 04:57 AM |
| Extra gain stage Marshall plexi 50watt | edsmith | Tubes / Valves | 1 | 22nd March 2004 05:58 PM |
| Page generated in 0.07682 seconds (69.13% PHP - 30.87% MySQL) with 11 queries |
