Old 22nd July 2008, 10:48 PM   #1
Default Regulation really needed for SF
In a class A small signal source follower circuit the total current out of the power supply should, it seems, be fairly constant. So the question is... if the PS is well filtered is voltage regulation really necessary?
mike - www.keepingsundayspecial.org
Old 23rd July 2008, 06:29 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
You gave already your own reply...if it's well filtered there's no reason to regulate it. Unless it's not well filtered enough for you
For ClassA source followers you can always use another follower as regulator (with Zener stack at gate), its output impedance is not that great, but sufficient for ClassA (see Nelson Pass Zen articles).
But for line-level stages a lot of cheap regulators are available, so why not use them if you're worried?
Have fun, Hannes
Old 23rd July 2008, 09:20 AM   #3
AndrewT is online now AndrewT  Scotland
but the supply current is only near constant in the quiescent (no signal) state.
The supply currents are modulated by the signal and can vary from zero to double the quiescent current.
regards Andrew T.
Using 0D3's for DC regulation in Aikido cbutterworth Tubes / Valves 29 21st February 2008 04:26 AM
needed 317/337 double regulation jaudio Power Supplies 17 19th June 2006 07:24 PM
Zen Regulation hacknet Pass Labs 3 5th April 2004 08:21 AM
Transformer regulation dhaen Parts 5 3rd February 2004 09:16 PM
LC regulation??? Michel Solid State 4 30th October 2001 05:42 AM
Page generated in 0.10821 seconds (55.50% PHP - 44.50% MySQL) with 10 queries
