Blu Eyes Amplifier
if you look at the input trannie phasing and the way the output transistors are connected, yes it is a P-P (push pull doesn't have to have the output transformer in the collector circuits to be push-pull. most solid state amps are push-pull). if it were single ended, the top transistor would not be driven by the input trannie, it would be a current source.
