Old 22nd July 2008, 02:07 PM   #1
Default nad 3020 clicking sound when playing
Hello, Diyaudioers:
I recently bought a nad 3020 on ebay for $120.
But there is some clicking or cracking sound from it when playing,
I doubt it is from the input selector buttons.
There are 4 input selector buttons: aux, tuner, phono, tape.
and there is a loudness button and a audio muter button.
The clicking sound is different from that produced when I push and release the buttons,
very crisp and short, and it is especially obvious when I turn the volumn low to loud.
Normally the clicking sound does not affect the music, but occasionally it will cut the amp off with no power output.
Can you give me some troubleshooting guidelines on it?
Thanks!
Old 22nd July 2008, 02:20 PM   #2
analog_sa's Avatar
Default Re: nad 3020 clicking sound when playing
Not really. Your description is not particularly specific.
You can make sure that it is indeed the preamp section to blame by removing the jumpers at the back and plugging a source with a built in volume control in the power amp section. Once the power amp has been cleared you can try to see if all preamp inputs behave the same way and this will eliminate the source selector. Are both channels equally affected?
It is really amazing how well the value of an entry level amp has kept up with inflation. I remember paying less than $90 for a brand new one around 1981.
Old 22nd July 2008, 03:08 PM   #3
So its not the old volume control pot that needs a good clean? Had the same amp and the volume pot needed replacing to function well on low to medium volume.
Old 22nd July 2008, 09:36 PM   #4
Default Re: Re: nad 3020 clicking sound when playing
Thanks, I will check that.
The headphone output works perfectly and there is no clicking sound when I plug in my hd650.
with the clicking sound, the right channel of the speaker will intermittently shut off.
Old 22nd July 2008, 09:36 PM   #5
Thanks.
In fact, the volumn knob is smooth. and I can't think of clicking sound comming from the knob...
Old 22nd July 2008, 09:36 PM   #6
I think I overpaid for that and it does not work well after I bought that 3 days ago. I was overwhelmed by reviews on line and did not know the original price.
Thanks.
Old 22nd July 2008, 09:51 PM   #7
analog_sa's Avatar
Default Re: Re: Re: nad 3020 clicking sound when playing
This may actually explain all. The headphone connects to the same output as the speakers but through resistors. There is a thermal fuse at output which disconnects the speaker connection under excess current conditions. It may also click. Very possibly it requires a replacement. It's easy to test by short-circuiting it underneath the board. Before doing that it may be advisable to check output offset and bias current.
Old 23rd July 2008, 05:10 AM   #8
Default Re: Re: Re: Re: nad 3020 clicking sound when playing
Thank you Sir.
I searched the web and got a schematic for it. I am not sure which is the fuse you are refering so I circled the one I suspect is the fuse. Could you please tell me if it is correct?
I have also got a picture of the 3020, could you please tell me which one is the fuse I need to replace.
Old 23rd July 2008, 05:29 AM   #9
Default Re: Re: Re: Re: Re: nad 3020 clicking sound when playing
Thank you Sir.
the left is my 3020.
Thank you Sir.
Old 23rd July 2008, 07:54 AM   #10
analog_sa's Avatar
It is marked as TB1/TB2 on your circuit and it's right between the zoebel and the output inductor. It's a bimetal automatic fuse and i have no idea if it's easy to find a replacement, nor do i know at what current it trips. 10A? My guess is that yours is tripping early. Or you really listen loud.
Not enough resolution to spot them on your board picture but they should be close to their corresponding inductors. Square cross section, about an inch tall, black, two pins at the bottom iirc.
Again: before replacing or shorting check bias and offset just to be on the safe side.
nakamichi cd 700 clicking sound plz help !! anton-sa Car Audio 3 22nd December 2008 05:10 PM
CLICKING Sound when spinning CDs on Pioneer DV-575A ,HELP...laser or what??? stifa Digital Source 6 24th November 2007 01:07 AM
about the difference in sound quality between the two NAD amps. 3020 and 3225 tube shop Solid State 4 4th September 2005 08:33 PM
NAD 3020/7020 sound drop-out bardsleyh Solid State 2 26th May 2004 12:23 AM
Pioneer SX-838 -- random no sound output, clicking relay VTbimmer Solid State 11 26th February 2004 12:12 AM
Page generated in 0.17308 seconds (54.88% PHP - 45.12% MySQL) with 11 queries
