Vbe Lowest? In lownoise bipolar transistors - Page 2 - diyAudio
Old 22nd July 2008, 02:09 AM   #11
sandyK is offline sandyK  Australia
Default Vbe Lowest? In lownoise bipolar transistors
lineup
The dual PNP SSM2220 may be worth a look at too. May not be so easy to come by these days, though.
SandyK
Old 22nd July 2008, 03:36 AM   #12
lineup is offline lineup  Sweden
lineup's Avatar
SandyK.
I was wrong about LM394.
This super matched low noise pair is still in production.
Strange we do not see these excellent bjt in more hi-fi amplifiers input stages.
AndrewT.
You were absolutely right about ZETEX small signal transistors.
For example when running low voltage simulation,
ZTX689B has got only VBE = 0.505 Volt at 0.5 mA
... this is low base-emitter voltage!
lineup
Old 22nd July 2008, 12:01 PM   #13
Mooly's Avatar
Is it for any particular application you need this or is it just a bit of fun/research ?
Old 22nd July 2008, 12:24 PM   #14
Originally posted by lineup
SandyK.
AndrewT.
Maybe your model is wrong, as the datasheet shows 0.59V at 0.5mA.
Old 22nd July 2008, 12:52 PM   #15
Elvee is offline Elvee  Belgium
Elvee's Avatar
If you want a really low Vbe from your LM394 or any dual transistor, you simply have to use half of the pair as a heather.
With a metal can, you can probably reach 200C reasonably safely, which will halve the Vbe.
As a bonus, this might confer to your design tube-like qualities, such as "warmth" in the sound (and inside the box too).
LV
Old 22nd July 2008, 12:56 PM   #16
my copy of the 689B datasheet (may'94) goes down to 1mA. Tc=25degC &1mA Vbe~=0.5Vbe
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd July 2008, 02:49 PM   #17
darkfenriz's Avatar
I would either go FET or use a DC-DC converter.
Old 22nd July 2008, 06:14 PM   #18
Mooly's Avatar
LV
On a single "AA" cell
Old 22nd July 2008, 06:36 PM   #19
lineup's Avatar
LV
Elvee.
Interesting idea. I remember that one.
Now for BATTERY, one or two, 1.20-1.50 V / 2.40-3.00 V,
we must consider current consumption.
We want our batteries to last as long as possible.
AndrewT.
ZTX689B is the device I have put into my low voltage opamp.
It now has been simulated to work rather well at +- 0.500 Volt supply.
The VBE drop is like you say 0.490 - 0.505 Volt.
At least in the spice models I have.
Of course I run my transistors at low currents:
150 uA and to max 500-700uA for the output stage
It is a convential basic opamp =
1. Input differential NPN LTP, two ZTX689B, fead by CCS
2. Current mirror on top: Two ZTX718
3. PNP VAS=OUTPUT .. right now ZTX718 .. fead by CCS number 2.
Of course use Output from Collectors.
To achieve output like +- 400 mV peak at PSU 1.0 V Battery.
4. Both current sources uses ZTX689B with that low VBE drop
and low Saturation Voltage
Notice that if you use rechargable batteries, NiMH 1.2 Volts nominal,
they often have like 1.0 Volt , when empty and need to be charged again.
What is left for me, is to see if anyone of ZETEX NPN transistors
will work better than ZTX689B. ( Less THD % )
For PNP ZTX718 seems to be the best
FARNELL, UK, sells:
http://uk.farnell.com/9525602/semico...=zetex-ztx689b
http://uk.farnell.com/9526536/semico...u=zetex-ztx718
DATASHEETS: ZTX689B and ZTX718
http://www.farnell.com/datasheets/62411.pdf
http://www.farnell.com/datasheets/58736.pdf
Lineup .. Sweden July 2008
lineup
Old 22nd July 2008, 07:40 PM   #20
Nordic is offline Nordic  South Africa
Nordic's Avatar
If current consumption is your main worry, why not look at J201... you'll need more voltage I guess, but you can bias them pretty low...
Bipolar transistors required mickb Swap Meet 0 31st January 2008 10:27 PM
TO-3 Bipolar Output Transistors danville Solid State 31 14th February 2007 10:04 PM
which is lowest noise bipolar? bane_982 Parts 1 4th March 2005 12:45 PM
MOSFETs or Bipolar Transistors? bigparsnip Solid State 4 11th June 2003 01:37 PM
Copyright 1999-2017 diyAudio
