Old 20th July 2008, 05:24 AM   #1
keantoken's Avatar
Default Has any one done this before?
Hello.
This is obvious enough it shouldn't be only me who's though of it.
Basically, you sidestep the problem of a capacitor on the output of a class-A amp by taking the feedback signal from point after the main output capacitor.
Here's a quick MS Paint scribble that I coughed up to illustrate my point. It should be readable.
If one is clever in their design, one may not need to include a DC blocking capacitor in the feedback path.
- keantoken
Old 20th July 2008, 07:08 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Yes.
This has been done many times in the past.
Both in pre- and power amplifiers.
If coupling this feedback rail with capacitor, you get only AC feedback.
lineup
Old 20th July 2008, 08:04 AM   #3
Nelson did it in the ZEN Revisted 1994 article....It's a interesting topology to lineaize the Cap ...
http://www.passdiy.com/pdf/retofzen.pdf
chrz,
T
Old 20th July 2008, 08:35 AM   #4
unclejed613's Avatar
or another way would be to make a bridged class A with the speaker connected directly to the outputs (no capacitors). there would be no DC offset across the speaker, but the voice coil would be at a DC potential.... panasonic uses a similar scheme with their class D amps which use a single ended power supply.... another added benefit is double the power. another way to do it WITH the cap would be to do a DC level shift to the feedback. either method would keep reactive components out of the feedback loop.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 20th July 2008, 10:02 AM   #5
djk is offline djk
djk's Avatar
http://home.comcast.net/~g.e.dunn/ST120/schem2.jpg
Candidates for the Darwin Award should not read this author.
Old 20th July 2008, 05:00 PM   #6
dynaco st-80?.......
Old 20th July 2008, 05:46 PM   #7
djk is offline djk
djk's Avatar
ST-120, but they are more similar than different.
Old 20th July 2008, 08:10 PM   #8
duhh..... if i had looked at the URL closer i would have known that....
one could also make a class A amp with split rails and a diff amp, and eliminate the output cap that way. it would provide a lower output impedance too... i think the bridged class A is the best way to do it with a single ended supply. it's pretty easy to make an inverting buffer suitable for the application. as a matter of fact the Dynaco amp could be operated like that without output caps, you just need an ST-120 for each channel....
Old 20th July 2008, 09:09 PM   #9
KSTR is offline KSTR  Germany
KSTR's Avatar
Another excellent example (and not only in this regard):
http://www.angelfire.com/ab3/mjramp/simple1.html
- Klaus
Old 21st July 2008, 12:10 AM   #10
keantoken's Avatar
This is great, now I have some more study material.
Are there any downsides to doing this?
- keantoken
Page generated in 0.12915 seconds (72.33% PHP - 27.67% MySQL) with 10 queries
