Hello
I was thinking of building an audio amplifier. I have not decided on the details, eg what supply, what wattage, except I am not too keen on huge voltages across the rails. I was thinking of a single sided design but that requires a trick at the end, some means of isolating the emitter of the output transistors from the speakers so we do not send DC down the speaker. For that two options have been suggested to me: a capacitor or a transformer. Assuming the transformer route, would you be able to advise me if it is possible and what type it would need to be and what calculations go behind it? Many thanks akis |
#2 |
something wrong ......single power sup means capacitor in the output .....
end of story nothing else except you are talking tubes
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 | |
For anything over a few watts, getting the transformers is probably going to be a pain in the ****, but not impossible. Before you go asking why anyone would want to do this, the obvious answer is for the fun of it. |
#4 | |
What about a bridge? |
#5 | |
#6 |
solid state RF amps use transformer output coupling all the time (for impedance matching) with both single ended and bipolar supplies. to do this with high power audio frequency would require a very large transformer.
#7 |
Hi akis
Sowters will generally wind transformers to specification, but they are expensive. A 50-watt output is going to need about 1.5 inch core (USA EI150, imperial pattern #120), and you'll have to drive it from push-pull, not a SE amp. (unless you use a capacitor first) But you get to specify the operating voltage! Here's how I calculate it: define a characteristic dimension a as the outer limb width of the core (for a waste free EI core, and which also equals the width of the "I" plates and bobbin window; the central core is then 2a) a=[power/(4.44x12xFBSUJ)]^0.25 where B=max flux (tesla) f=lowest frequency (Hz) S=stack height to width ratio (normally 1) U= utilisation factor of copper to window space (a number<1) J=max current density in wire (A/sq m) Bet you want to know what these should be? The main problem I suspect will be obtaining the cores, bobbin and mounting hardware. Copper is probably twice the price since I last bought any, and for a largish transformer you'll need around 1 kg of wire or thereabouts. And driving such a beast will not be easy. It used to be done in the 1950's with another transformer, but it is possible to arrange capacitor-driven phase splitters with some difficulties. I happen to think that capacitor coupled amps should be OK these days with modern low inductance, low impedance power supply types, but many will say don't. I have not checked the distortion arising in such caps, but they ought to be better than the older designs. For a first amp I would strongly recommend a cap output. If you short something, there is a better chance that not everything will be destroyed. direct coupled amps which are not debugged can wreck everything easily! cheers John |
#8 |
Hi
I built a small (couple watts) amp once using a transformer output. The output transfo secondary Z was 8 Ohms. There was only 2 PNP transistors in the circuit. I used an input transformer to split the phase, amplified to the centertapped primary output transformer to match Z to the speaker. Super simple, but not exactly "high end".
All the trouble I've ever been in started out as fun...... |
#9 |
Hello
I was sure I replied but cannot see my reply anywhere. To elaborate, I have not decided on power yet, but I presume a single supply rail of 60 Volts sounds safe enough if you touch it. I was planning to have a bunch of transistors in common collector configuration at the output, supposing we have the emiiter at, say, 30 Volts and supposing that we do not care about swinging end to end, say we only care to swing +/-20 volts from there, so we leave 10 volts on either side. That would give us an output voltage of 14 Volt RMS, ie a theoretical power of 25 Watt RMS into 8 Ohm or 50 Watts into 4 Ohms, assuming we could somehow transfer that power. So now we have a transistors emitter idling at 30 Volts and wanting to swing from 10 to 50 Volts and somehow we need to somehow connect that to the speaker. This is where I need some ideas/help Employing solutions involving large number of transistors or other complicated schemes defeats my purpose. Of course I am quite ready to accept that what I ask is either impossible or completely impractical (eg requires more transistors than a push-pull design). |
#10 | |
Some of my earlier amp designs used +/-40 volts but they lacked the dynamic range required by CD's. Transients were clipped with not a lot of volume. I now go for at least +/- 60 volts to get a good range.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.13308 seconds (77.57% PHP - 22.43% MySQL) with 11 queries |
