Old 17th July 2008, 11:24 AM   #1
zakzak is offline zakzak  Syria
Default hellp dirty hirry amp?
hellp for other changes
Old 17th July 2008, 02:32 PM   #2
wg_ski is offline wg_ski  United States
What? The base stoppers? Whether they're needed or not depends on how clean the layout is. With MJ1502x's, if the pcb is as clean as Fotios' is, then you don't need them. If you'll have wires running all over the place you probably will. If you've got anything in there that can make the output stage less stable - long leads running to the reservoir caps, more than two channels sharing the supply, or any sort of rail modulation you'll need them as well.
As for using the full-size driver transistor, one has to wonder why Fotios used the lower power version in the first place.
Old 17th July 2008, 03:33 PM   #3
sakis is offline sakis  Greece
sakis's Avatar
Default you may ask
fotios directly for anything you want i belive
you will find that he is a very nice and helpfull guy
(presuming that you are not willing to alter his design )
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Hellp with AudioTester 2.1 a007udio Multi-Way 6 24th March 2007 12:26 PM
Quick and Dirty X-over bjackson Solid State 1 16th August 2005 06:32 AM
OTL, quick `n dirty Fuling Tubes / Valves 4 27th December 2004 07:44 AM
Hellp from Guraqiy Esra Yeknom Introductions 3 16th January 2004 12:50 PM
cheap and dirty sub hacknet Solid State 20 19th December 2002 04:14 PM
Page generated in 0.08166 seconds (67.38% PHP - 32.62% MySQL) with 11 queries
