Old 17th July 2008, 08:16 AM   #1
Brit01 is offline Brit01  United Kingdom
Default Bi-wire with old Yamaha AX-570?
I have an old Yamaha AX-570 that has 2 sets of speaker terminals. This amp is reated at 100w (8 ohms). Is this power split between the 2 sets of speaker terminals?
If I bi-wire my pair of speakers with the 2 sets will this just end up splitting the 100watts? Will I not get any sound improvement with this set up?
Should I just use standard wiring technique with one set of speaker terminals?
Also this model has a pre-out/main in function. I would like to use a pre-amp (valve amp kit); Can I use the valve pre-amp and connect into the main-in function to use the yamaha as a power amp??
Thks
Old 17th July 2008, 08:47 AM   #2
Greg Erskine's Avatar
Hi Brit01,
The A/B speaker terminals are connected to the same output of amp. So if you bi-wire it will make no difference if you connect to the A and B terminals or both wires to the A terminals.
Will it make a difference? Maybe?
I have a AX-550 and I used to bi-wire it connecting to the A and B terminals. I thought it sounded better bi-wired.
So, just try it and see, nothing to lose you are due for a new amp.
regards
Greg Erskine
Old 17th July 2008, 09:17 AM   #3
Thks Greg.
I'll give it a shot.
New amp is out of the question at the moment unfortunately. Maybe next year (will take a while to convince my girlfriend the money will be well spent!). Besides that I'm in Uruguay and the prices are rediculous.
I'll have to smuggle one back in my suitcase from UK when I visit my old folks!!
Old 17th July 2008, 09:20 AM   #4
Greg,
Did you use 1 speaker set for the bass and the other for the treble or split them?
Thks
Old 17th July 2008, 09:41 AM   #5
Originally posted by Brit01
Greg,
Thks
I used thick wire for the bass to the B terminals and thin wire for the tweeters to the A terminals.
Just keep in mind what you are effectively connecting in parallel. If you connect 2 sets of 4 ohm speakers then you may get into trouble (not really bi-wiring).
regards
Greg Erskine
Old 17th July 2008, 09:45 AM   #6
Cool.
I've got a pair of Klipsch F-1, 93db, 8ohm. They're fairly efficient so shouldn't have a problem.
Old 17th July 2008, 11:47 AM   #7
Gauge 18 ok for the treble do you think (it's what I have in stock now)? What about the bass?
Thks
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
Proper Wire for Wire Wrapping DreadPirate Parts 5 19th August 2008 09:58 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Page generated in 0.09801 seconds (70.13% PHP - 29.87% MySQL) with 10 queries
