Crest CA12 Bias Setting anyone have info?
Old 13th July 2008, 11:29 PM   #1
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Default Crest CA12 Bias Setting anyone have info?
Anyone have any info on how to set the BIAS for a crest CA12 power amp??? I just repaired one channel and i need to adjust the bias now and while i have most of the schematics for the CA series. nothing has any mention of BIAS adjustments.
Zc
Old 3rd August 2008, 05:15 PM   #2
Photones is offline Photones  United States
Default Crest CA-12 shematics?
Sorry,no bias info but I need a schematic for a CA-12 if you or anyone is willing. Much appreciated.
Old 4th August 2008, 02:59 PM   #3
zoranaudio is offline zoranaudio  Macedonia
zoranaudio's Avatar
If you can't get the schematic just set bias current to about 20 to 30 mA on one line plus or minus( per each transistor) because there is more paralel output tr. via emitter resistor.
Or easy just adjust bias acording to the measure voltage on one of this emitter resistors.
Ibias=V resistor(V)/ R resistor(ohms).
example: If you like to set bias to 20mA and R resistor is 0.22 ohm, you should measure 4,4mV or 0.0044 Volts.
Vresistor(measured voltage)=R(emitter resistor)*I bias(desired bias current),.
So if you like to set bias to 50 mA and resistor is 0.22 ohms than you should adjust voltage across the resistor to:0.22(ohms)*0.005(A)=0.011Volts or 11 mV.
I hope this will help you until you find original factory settings, but I think that Crest is for professional Audio(high power) not for high end and home listening so better keep bias lower about maximum 50mA on Transistor (each) than higher.
zaudio
Old 4th August 2008, 07:22 PM   #4
zoranaudio's Avatar
Sorry for mistake in current!
So 50mA=0.05A
Result:
0.22(ohm)*0.05(A)=0.011V or 11mV
zaudio
Crest CA12 Bias Setting anyone have info?Hide this!Advertise here!
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
How to get cathode bias info from grid bias info? leadbelly Tubes / Valves 8 14th August 2008 05:40 PM
Setting Bias kptseng Solid State 9 8th March 2008 02:56 AM
bias setting ben goh Solid State 8 14th August 2006 05:26 PM
Problems with bias setting Cicero Solid State 5 21st January 2005 09:01 AM
Copyright ©1999-2017 diyAudio
