I just made a TDA2003 amp for my PC. I set the gain resistors at 4.7 ohm and 220 ohm. When I plug in the audio source, there is too much distortion that the actual music can barely be heard. I am running it from a 12v 4a power source i built myself. What could be the reason for the distortion? What can I do to remove it? I thank you in advance for any help i can get.
The tallest building in the world starts from the first brick. পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে। |
#2 |
Magneto the Gravity Man
post the circuit and values you are using.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
Here it is.
Please help me in this regard.
#4 |
why did you not use the circuit in the application notes?
http://pdf1.alldatasheet.com/datashe...S/TDA2003.html Andy
#5 | |
Replace C8 0.22u, now across speaker output, with one Capacitor 100nF + 1 Ohm in series, across speaker output. Like C5 + R3 in my attached example from TDA2003 datasheet. Datasheet TDA2003: http://www.st.com/stonline/products/...re/ds/1449.pdf
lineup |
#6 |
resistances.... and you have 220 and 4.7 ohms... this seems to me your gain will be 47. Your PC output signal goes to 1 volt.... with your gain will distort...the maximum output power is obtained with 4 volts output (more or less)..... so....you have to multiply (gain) your PC signal by a ratio of four... and not 47.... your resistances must be 220 ohms and 56 ohms, or 220 ohms and 47 ohms. This is your problem.... with 1 volt entering (alternated volts, audio volts) your circuit is trying to produce 47 volts...and this is not possible..so... too much gain means enormous distortion. The problem is just this one...... i can be wrong about those resistances, but for sure the gain has some preset alike that one. Search for datasheet and check your gain.... adjust it to 4 or 5....not more than that. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#7 |
TDA2002/2/4/5 have a really nasty habit of oscillating. Because the input is referenced to the same ground pin that carries high current, it's way too easy to have a bad layout. Not only do you need a star ground, but the resistance/inductance from the ground pin to the star ground needs to be minimized. If the chip gets hot just idling, then this is what's going on here. The output shunt cap does need a damping resistor, and it needs and ohm or two (not the usual 10 ohms). And be very careful where you "ground" it.
#8 |
Thanks everyone,
I'll try your suggestions out and post the output.
| Low Powered Inverting Amp (TDA2003) | rossco_50 | Chip Amps | 10 | 29th July 2009 07:31 PM |
| Help with Cana-Kit using TDA2003 | noob for now | Chip Amps | 1 | 8th December 2005 09:08 AM |
| TDA2003 hum ¿PSSR problem? | sync40 | Chip Amps | 3 | 2nd November 2005 06:40 AM |
| Page generated in 0.09698 seconds (75.86% PHP - 24.14% MySQL) with 11 queries |
