I have new solid state amp in mind, and just from looking at the block diagram, I can see that I (due to size limitation) need to stack the VAS stage PCB on top of the Output section PCB.
The distance between the stacked PCBs must be 15-20mm (0.6-7.9"). The signals going through the connector are mixed control signals, low Current audio and power signals (max 1A). Is there out there who knows of some good audio "PCB to PCB" connectors ? I have thought of just making wire connections, but would like the easyness of the connector type connection. Any help appreciated. Thanks in advance
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#2 | |
I have used many times those pin strips gold plated. Simply you can broke each pin from the strip to use it seperately. I don't know if you want the pcbs will be pluged between them so as can seperated easily. Me, i preffer to solder the pins in each pcb for the purpose to avoid any parasitic capacitance. You know what i mean. Also, take a look in Farnell site, there are gold plated Molex as i remembered. Also in "Selectronic.FR" site, there are many types of gold plated connectors and other goods for audio use. It is a nice store. Regards Fotios |
#3 |
I agree with the pins.... I buy them on long strips or a few cents...
and of course you get the strips in female too... They come in a variety of pitches and lengths and you even get angled ones. |
#4 |
Hello fotios
I do know these gold plated pin headers (use them a lot for jumper purposes), however I havn't came across ones that are long enough (20mm). However the short pin headers may be used, if the receiption is a vertical connector like on the attached picture (however I do not need this big space between PCBs. Thanks for the link
#5 |
Thanks Nordic
Anyone know if these are good and where to get these?
#6 |
I'll grab a few for you from the shop when I go on Monday... They definatly have them in longer versions, I think the long one is about an inch... It has two plastic strips to keep the pins seperated over the full lenght, instead of just the one strip at the base...
Waith they must be even longer, as I found a small piece from the medium sized pins... and they are 22mm P.S. super neat pins in your picture... |
#7 |
Sometimes the breadth of their catalog can be confusing, but Samtec specializes in this stuff, and will usually ship small quantities quickly.
I used to be an audiophool like you but then I took an arrow to the knee. |
#8 |
Thanks Nordic
Anyone knows the Farnell or RS part no. ? I have browsed their websites for hours, but didn't find the long ones that Nordic presented. Thanks for the tip, Conrad
#9 |
I get those from a small retailer... would hate to know what RS charges for them... as you could see from the picture the pins are completely untarnished after 2 years, even just lying in a little drawer... (I live by the sea)... I remember them being quite cheap... like cents I think....
#10 |
Yes they look just great, Nordic
I just hate to make a PCB layout with "hard to get" components... It could nice if they could be purchased locally later
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| Can Toroidals be stacked? | ben62670 | Power Supplies | 16 | 21st June 2008 02:47 PM |
| Stacked woofers | dsrviola | Multi-Way | 1 | 15th October 2006 02:35 AM |
| Zen v4 and stacked transformers | Zapped | Pass Labs | 3 | 21st November 2002 06:26 PM |
| Page generated in 0.10165 seconds (79.98% PHP - 20.02% MySQL) with 11 queries |
