Old 9th July 2008, 04:12 PM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Smile Complementary Class A Preamp using BC368-369
We do not often see BC368 BC369 used.
These are High Current 2000 mA TO-92 transistors.
The limitation is Max 20 Volt Collector-Emitter voltage.
But for preamp / headphone amplifiers these can be a very good option.
My example here is a Complementary Class A preamp, with 2SK170 / 2SJ74 input.
I use dual +-10 Volt (=20 Volt) for output stage. And a bit higher for Input/Vas.
For being a preamp, this one is POWERFUL and very low distortion.
Can drive Headphones, for example 32 ohm, with vanishing low distortion.
( Below -100dB, some 2nd order harmonics )
Notice. Important!!!
If you attach Headphones, be sure to use an Output Capacitor
Until you are absolute sure the DC- Offset is stable.
Because this amplifier has got not DC global feedback.
The AC global feedback is coupled with C3 = 100 uF to input JFET stage.
Enjoy
Lineup
File Type: png class-a_complementary_bc368-369_public-1b.png (44.6 KB, 1409 views)
lineup
Old 9th July 2008, 04:25 PM   #2
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
thanks for sharing.
how is the distortion across frequency?
1nF for miller cap lag compensation seems rather large ...
mlloyd1
Old 13th July 2008, 11:48 AM   #3
lineup's Avatar
Hi.
Revision 2.
Gain is now 5.
It is enough for a preamp. Mostly.
OpenLoop Gain in now lowered to ~ 500.
This gives a feedback factor of x100 ( 40 dB feedback ).
I post here 3 diagrams from my OpenLoop test.
This first shows the setup schematic.
2 mV RMS in.
LOAD is 100 Ohm.
Which actually means ~ 50 Ohm load
as the feedback divider ( R15, R14 ) is 82 + 20.11 = 102.11 Ohm
At OpenLoop Gain x512, THD is 0.153%
Lineup
lineup
Old 13th July 2008, 11:50 AM   #4
lineup's Avatar
OpenLoop AC Analysis, shows the gain bandwith.
And the Phase.
Lineup
lineup
Old 13th July 2008, 11:53 AM   #5
lineup's Avatar
Detail of the OpenLoop AC Analysis.
Shows gain +54dB at 1 kHz
As mentioned, open loop THD is 0.153%
Shows -3 dB Open loop bandwidth is: 70 Hz - 20 kHz
Lineup
lineup
Old 29th July 2008, 06:58 AM   #6
lineup's Avatar
Distortion vs. frequency?
I have only run 1 kHz. So do not know yet from higher freq.
I will do an oscilloscope run, to see the waveform.
Will be very interesting
Because this amplifier sure is another piece of cake than other preamps.
Very different
Regarding disortion against vs. LOAD.
LOAD has not much effect. (except for loads lower than say 32 Ohm)
Comes from the fact that current feedback is 100 Ohm load, already.
Feedback rail in parallel with 100 Ohm load,
gives a normal nominal load of 50 Ohm
Which is a good value to use, for this VERY POWERFUL preamplifier.
Say for loads higher than 1k .. we can not expect to notice any change in behavior at all.
Whatever parameter .... !!!!
You ask: 1 nF a bit high for compensation?
Well, I use not BC550C or lightweight TO-92 for VAS drivers.
BC639/640 are like BD139/140 in electrical quality.
And that value is on the safe side and also what gives best performance in my Sim.
In real life we may try with more or less, but in this sim-version
we use 1 nF.
Besides, a nice rolloff, reasonable close to audio band ( 20 kHz )
is something I often do.
Say 200-250 kHz.
I do not design Audio amps for RF performancy.
I leave this to others
Old 29th July 2008, 07:34 AM   #7
HKC is offline HKC  Hong Kong
Hi lineup
Very nice pre-amp design.
What do you think if BC368/369 substituted by 2N4401/4403?
BC368/369 is no longer available from RS & Farnell. I have plenty of 2N4401/4403.
Old 29th July 2008, 01:50 PM   #8
lineup's Avatar
2N4401 / 2N4403
and maybe 3 paralleled pair in the output of those
hmmmm...
The only thing that is needed, is that output transistors
should work fast and well & with good gain at:
- 10 Volt Collector-Emitter
- 33-50 mA Collector Current (for an idle Class A in output of 100-150 mA total)
This means upto 500mWatt heat. ( 10 V x 50 mA )
What I will do HKC, my HongKong friend,
is to read the 2N4401 and 2N4403 datasheet
and also try to find Spice Models for 2N4401/4403.
Then we will se. If they can come close to BC368/BC369 in performance.
Remember!!!
BC368 and BC369 are special transistors for very high currents operation.
They are small signal ( TO-92 ) rated MAX 2000 mA
Compare for example MAX DC Current, Average Current:
BC368/369 = 2000 mA
BC550/560 = 100 mA
2N5551/5401 = 300 mA
BC639/640 = 1000 mA
BD139/140 = 1500 mA ( TO-126 Power driver!! )
I have no problem with buying BC368 BC369
And they are available here in Europe.
see for example
http://www.dalbani.co.uk/catalogue/p...s.php?id=10005
http://www.dalbani.co.uk/catalogue/p...s.php?id=10006
if buying 10 pieces
from http://www.dalbani.co.uk/
they are not expensive at all:
BC368
£0.10
US $ 0.20
Euro 0.15
BC369
£0.10
US $ 0.20
Euro 0.15
Old 29th July 2008, 01:58 PM   #9
mlloyd1's Avatar
in revision 2, i see you've changed to 150pF instead.
that seems more reasonable to me.
mlloyd1
Old 29th July 2008, 02:05 PM   #10
lineup's Avatar
hi
Also I tried with different number of pairs BC368/369 in parallel output
For an idle total output current = 120 mA
Using 4 pairs, was no better performance than using 3 pairs.
Using 2 pairs makes these TO-92 a little bit hot. ( 600 mW continious )
Conclusion:
3 pairs is a safe operation
3 pairs is better than 4 regarding performance
3 pairs is optimal for this situation
FS: stuffed k134/j149 Mosfet Amp, Full Complementary Symmetry FET Preamp boards honinbou Swap Meet 13 29th April 2007 04:47 AM
How important is complementary transistor pair matching in class B amp? caesar148 Solid State 10 15th October 2004 07:06 PM
Single Vs Complementary Vs Differential Comparators in Class-D Workhorse Class D 0 27th May 2004 01:18 AM
Complementary Zen- class A or AB? needtubes Pass Labs 2 22nd April 2004 12:43 AM
Page generated in 0.20153 seconds (57.40% PHP - 42.60% MySQL) with 11 queries
