Old 9th July 2008, 02:01 PM   #1
TzeYang is online now TzeYang  Malaysia
Default Cascode VS Wilson Swapped Mirror
I'm sorry if this is asked before. I've tried searching high and low for the answers but unfortunately they don't have sufficient information. I also searched this forum.
http://www.edaboard.com/ftopic87893.html
I found the above link to be the closest to the answer but still insufficient to meet my demands.
basically, i'm looking to use either wilson swapped or cascode current mirror for my diamond buffer. I'm not sure which one would be better theoretically. Simulations gave me slightly lower THD with the Wilson Swapped.
i also plan to use it for the folded cascode stage on my discrete amplifier. Any suggestions?
Thanks.
Old 9th July 2008, 02:07 PM   #2
homemodder's Avatar
Hi
Could you put up a simple schematic to show what exactly you mean.
Alex
Old 9th July 2008, 03:00 PM   #3
This would be an example.
EDIT: I'm looking for a comparison between these two mirrors specifically for bipolar junction transistors. Thank you.
Old 9th July 2008, 03:12 PM   #4
KSTR is offline KSTR  Germany
KSTR's Avatar
The cascoded normal current mirror/CCS typically has a better transient response (no overshoot), but the Wilson has a bit more bandwidth, at the cost of overshoot. More benefitial to your design might be the use of BJT's with high early voltage (that is, BC5xxA's in your example) for those transistors which have big Vce voltage swings.
- Klaus
Old 9th July 2008, 03:24 PM   #5
So it's better for my buffer to use the Wilson Swapped Current Mirror instead right?
Also here's another circuit i would like the apply the mirrors to:
Reference: Diamante Folded Cascode Amplifier by Russ White.
The mirror at the folded Cascode stage. Which one would be better for the application? I'll probably use 2N5088 2N5087 or BC560C BC550C
Thanks.
Help with improved Wilson current mirror nelsonvandal Solid State 13 30th November 2008 03:26 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
Noise floor rise on heathkit W4-AMs when power supply transformers were swapped terminatorx Tubes / Valves 4 8th October 2006 01:31 AM
swapped OPA2132 for AD8620... dorkus Digital Source 15 22nd January 2006 09:01 PM
HELP! i swapped plus and minus! Smithers Pass Labs 10 5th January 2003 02:19 AM
Page generated in 0.09929 seconds (64.35% PHP - 35.65% MySQL) with 11 queries
