Hum noise on my swr sm400s
Old 9th July 2008, 12:20 PM   #1
davbass is offline davbass  Italy
Default Hum noise on my swr sm400s
Hi
I've replaced the 12ax7 tube on my sm400s, but it produces
a little 50Hz hum noise in hi gain condition on preamp section (some volume level then 'shhhhh' noise).. this hum increase when i boost the bass on eq section.
another costant hum noise (test condition: input of power amp section shorted and master = zero) come from the two power amps modules
a mechanical vibration (50Hz) also compare on all chassis.
can anyone help me to eliminate hum in preamp section and in power amps sections?
TnK
Old 9th July 2008, 04:18 PM   #2
chicago_mike is offline chicago_mike  United States
I have an sm900 that I have to work on some and noise is an issue. But for me I can hear the fan thru the amplifier AND i can hear the posts move...so something(s) are picking up noise they shouldn't.
The tube could be microphonic or I, we, could have a couple bad opamps, or even the power supply could use some updating.
Theres a guy named dave around here who is a real good swr repair guy, a guru pretty much.
hoping he chimes in when he can.
Old 10th July 2008, 12:47 PM   #3
tnk mike
the hum is a problem for me in recording session..
so, i tryed:
- disassebly the front panel from the rest of chassis, the hum in peamp section (on post eq DI output ) disappairs. The signal is totally hum free
it doesn't improve:
- I changed the fun AC power supply in DC whit a diode 1n4007 and a 4700uF cap (sm500's mod)
- I rewired with shelded cables the signal patchs in 12ax7 section
- I repalced all op amps
- I tryed, also, to detach and rotate of 90 degree the power supply trafo (3/4 cm 'on air' from chassis)
I have noticed that one of two power amp module have a thread connected to the AC sec of main trasformer (into the AC/DC bridge), so i think this is the reason of the hum in this sections..
Hum noise on my swr sm400sHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
Red LED noise. GK Solid State 5 14th December 2006 03:12 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Hum and Noise with Ono rsbay Pass Labs 0 26th February 2006 12:51 PM
DSP and DAC noise nFORCE Digital Source 4 29th April 2003 03:18 PM
Copyright ©1999-2017 diyAudio
