#11 |
Edmond - ok - I agree no point in starting futile arguments. I just want to see for myself.
JCX- I unticked the compression boxes in the control tab - I assume thats the the same as applying the directive you refere to? KSTR - are you refering to my cct or the blamles s amp? my circuits CFA - miller cap makes it oscillate. To improve phase margin, the recomended technique is to apply a filter to the front end. I found triming the VAS cap also helped (sim'd with square wave input). Traderbam - good point, but my only concern is that the input would have to be attenuated at the same time in order to keep the output level constant (it would be less useful to trim the output through a pot becuase this would raise the output impedance and there is also the output saturation issue to deal with. |
#12 | |
- Klaus |
#13 |
C1 isn't strictly a Miller cap, though...what I see is a transconductance amp driving an RC shunt to gnd, then a voltage buffer to the o/p.
I predict this circuit will be prone to instability without proper miller compensation. What if you made an ordinary circuit, forget the symmetry thing, with an ordinary miller VAS? Then you could easily vary the OL gain by having a variable R across the miller cap (with dc blocker). This would have the effect of turning the VAS into a variable low pass filter. IOW, a transconductance, differential input stage feeding an integrator with variable corner frequency, then a unity gain buffer to the output. |
#14 | ||
![]() - Klaus |
#15 |
Klaus, I didn't mean to be nit-picky...I know you know what you are talking about. Just trying to avoid confusion of the passer-by.
![]() Regarding stability of simulations correlating with stability of real circuits. Ha, how much time have you got?
#16 |
This is a small signal amp - so the output would be fed via an isolating resistor - e.g. 20 to 50 Ohms. This would remove any problems with load capacitance - I should have shown that in the circuit for completeness.
#17 |
If you are interested, there is another way to do what I think you are trying to do. See conceptual circuit below. Might be simpler to implement and will be very stable. That is to use a wide-band differentiator (U1) feeding an op-amp (U2). Varying R4 will vary the feedback factor without changing the GBP. U1 can be a transconductance amp too, or a discrete subtractor like you have in your current design. U1 needs to have a GBP greater than U2.
I would have thought a couple of decent, off the shelf amps would do. |
#18 |
Thats neat traderbam. It can be done with discrete op-amps and IC types.
| hi-loop gain amp | mfc | Solid State | 49 | 10th January 2009 07:10 AM |
| open loop gain,how many is enough? | Leolabs | Solid State | 28 | 17th May 2006 10:00 PM |
| Loop gain question | lumanauw | Solid State | 55 | 16th December 2005 10:59 PM |
| Gain loop formula | fscarpa58 | Everything Else | 2 | 16th January 2004 12:19 PM |
| Variable Gain preamp? | Nisbeth | Solid State | 8 | 5th June 2002 12:46 PM |
| Page generated in 0.11580 seconds (74.92% PHP - 25.08% MySQL) with 11 queries |
