Naim (split from Blowtorch)
Old 5th July 2008, 05:17 PM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally posted by john curl
[snip] Julian owned the company, so he only had to answer to himself, [snip]
Wrong. If I am his customer, he answers to ME. Period.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 5th July 2008, 05:27 PM   #22
snoopy is offline snoopy  Australia
Banned
It is NOT the topology that Naim uses, but the way that it is implemented. You know, no E-I protection, no output coil, etc. Yes, it makes it non-bulletproof. Julian owned the company, so he only had to answer to himself, and this gave him a sonic advantage. Can't you understand that what a lowly engineer must do to protect himself from being fired, IF something goes wrong with an amp, and he only had to restrict the peak current, and add a output coil, to remove the potential problem? Julian went for 'sound' first, absolute reliability second. Much like Lotus made race cars. Julian used to race cars, so maybe that is where he got that approach.
If he was a wiz bang designer as you claim him to be then he would have made the product both better and reliable at the same time. He obviously didn't know how to make it better so instead he chose to take shortcuts that any other manufacturer could have made and in the process made the whole product unreliable and a potential hazard to the loudspeaker that it was connected too
How could anyone be impressed with that record
Old 5th July 2008, 05:27 PM   #23
john curl is offline john curl  United States
john curl's Avatar
Jan, Julian is dead and gone. Why can't you leave it alone? Coils are not really necessary today, BUT they were important then, IF you also used an exotic cable that had NOT been for sale at the time that Julian made and sold the bulk of his power amps. It was only later that he had problems with so called 'Polk cable' and he had to issue warnings against using hi cap wire, and even made his own 'zip cord'. He could have offered a coil to do the same thing, but he, like me, found that this effected the sound in a bad way. He did it years before me, as well.
"Condemnation without Examination is Prejudice"
Old 5th July 2008, 05:36 PM   #24
bappe is offline bappe  Sweden
bappe's Avatar
Default Re: Re: Re: Re: What is the problem with Quasi-complementary?
Originally posted by snoopy
Rather than offer your subjective opinion can you answer the question why you think this design topology is better than most new amplifier designs ??
As i said, i play music through it, i like it, and after that i try to get "inside" the design to figure out why i liked it. Besides i think i did give you an answer in the last post. Also, some (modern or old) amps sounds so bad that you wonder if their designer listened to them at all.
/Anders
Old 5th July 2008, 05:40 PM   #25
jan.didden's Avatar
John, this is not correct. Naim specifically told their customers to use THEIR cable because otherwise the amp might self-destruct. (Well, to be honest, I think their wording was that their cable 'brought out the best of the amp'. But most of us know how to translate that). Nothing to do with as-then unknown boutique cables.
And it was you who brought up Mr Vereker as the man who also managed to leave out the coil. Apparently you forgot, or were not aware, that that move made the amp unreliable. The same point Bob has been making independently, as well.
You brought the whole thing up, people noted that your reasoning didn't hold, and now you want us to 'leave it alone'. You should have thought that through before.
Jan Didden
Old 5th July 2008, 05:51 PM   #26
john curl's Avatar
Jan, AT THE TIME, that Julian made the decision to leave out the coil, he found that the zip cord that everyone used at the time, added enough inductance and there was NO problem with oscillation. Remember, the time was the early 1970's. LATER, when exotic cables were offered, MANY amps tended to oscillate, coil or not, and had to be redesigned. Naim had to do SOMETHING to keep their customers from using exotic and hi cap wire, so they provided one for their customers to use, instead of zip cord, which was considered 'obsolete' at the time. This way, they controlled the inductance, and the amps remained stable, without adding a coil which makes a bigger negative difference to the sound than many here yet realize, especially with 2uH or more, which would be necessary to do anything useful in Naim's case. Remember, this was the 1970's. I suspect that in later years Naim ran on its own inertia, and Julian concentrated on other projects. He might be criticized for this, but it is 'water over the bridge', now.
Old 5th July 2008, 06:09 PM   #27
jan.didden's Avatar
Err... Ahum, Ehh, were I live, the water flows *under* the bridge.
But we'll burn that bridge when we come to it .
Jan Didden
Old 5th July 2008, 08:14 PM   #28
bear is offline bear
expert in tautology
bear's Avatar
snoopy,
My recollection - a non-technical one at that - was that Naim marketed well in Europe and then parleyed that into a US/North American presence, using the "Euro" angle for that. It appealed to those who did not want/like the typical American "big techno gear" look (Crown, Phase Linear, SAE, others...), and prefered that understated smooth look but didn't have the bux$ for B&O!
As far as the Japanese amplifiers of that day, not the Kenwoody or Pieonear receivers (etc.), my recollection is that they tended to be a bit lean, and often grainy to the ear. That especially being Yamaha and Mitsubishi stuff, Sony too... the exception iirc, is/was STAX.
Some of the Kenwoody and Pieonear recievers still sound pretty nice for casual listening - like the one doing background music in the lab here now... NP: Fillmore East 1970 GD...
General thought, my recollection:
Back in the 70's the trend "on the other side of the pond" was for smaller speakers, smaller amps, and a more "gentile" sound - less bass, smoother mids, less highs. Generally speaking rooms are/were smaller.
Not sure what Japan was doing other than chasing the USA market... although many back then were buying up the older USA tube and horn speakers even then...
Here in the USA, the trend was big bass, LOUD speakers, the most power you could figure out how to put together.
Different.
Jan,
I think that's "...bomb the bridges..." I think we're well past burning at this point??
1audio,
could you shoot me an email? the address on ur website bounces...
Mr. Curl,
Well, lessee, we've covered the circus, oops i mean the circuitry. That leaves the wiring, the switching and the GROUND(s)?? Afaik, none of that makes an iota of difference...
_-_-bear
PS. everyone else who complains too much?: Try to ignore your perception of Mr. Curl, focus on the wealth of information and insight that this thread embodies instead. Make a contribution, ask a question, illuminate an issue?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 5th July 2008, 08:21 PM   #29
On Hiatus
SY's Avatar
Suitable for church choral music, presumably.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th July 2008, 09:07 PM   #30
fredex is offline fredex  New Zealand
I agree with bear's comments
Naim were tied up wth Linn and shared dealerships, the Linn Naim system was pushed as a package. It was an antidote to the high tech Japanese 'new model every six months' idea. Hand crafted in England by people who cared about sound and it was tailored to British ears. The sales people were all well trained and told you what to listen for in the sound. The competion were still selling on specifications. This marketing strategy worked well as it was very "timely". These days we are all a little more cynical ........ or is it just me?
Naim (split from Blowtorch)Hide this!Advertise here!
