Old 5th July 2008, 01:12 PM   #21
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
Space2000, you have a gift to not answer quiestions, so once again:
How thick are the fins?
What is your target thermal resistance, or what power do you plan to dissipate on that heatsink?
I think that you could improve it a lot if you used for example U-shaped fins instead of L which you have now.
And the second thought is that you can stack the Us in layers, you maybe could have even 3 U-fins ontop each other, attached with the two bolts.
The problem is that you need the flattest surface possible on both sides, so you could press it on some matrice and then grind it.
Old 6th July 2008, 01:35 PM   #22
Default update heat sink with class A amp
dear all,
i just tried my heat sink by using class A amp. Today nothings to do due to Dx-turbo rebuilding so i was wondering testing for class A amp.
i build Aleph-3 30 watts last time so i put 6 mosfets on it.i think watts should be more then 30w due to high ampire, i am using 10 ampire. i used one channel on my heat sink, i was surprised lots. after and hour run the temp is only 34c and my amb is now 29c night time.
i think the heat sink is working very very fine.
picture is attached. pls don't see the mass....ok...i just was testing heat sink parformence.
thank you
michael
Old 15th July 2008, 12:08 PM   #23
Just completed the box for Dx-turbo with this heat sink. all are home made. ha.....ha....it is Dx-turbo....
thank you.
LM3875 heat sink help. CJ Paul Chip Amps 4 10th March 2006 08:14 PM
Heat Sink Question darth_audio Car Audio 2 14th October 2005 04:47 PM
Required heat sink troystg Chip Amps 9 15th November 2004 01:40 AM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
Page generated in 0.06962 seconds (70.33% PHP - 29.67% MySQL) with 11 queries
