Old 28th June 2008, 04:07 PM   #1
mnr102 is offline mnr102  United States
Default led mount recommendation?
Can anyone recommend a mount for panel-mounting an LED? There's so many out there, and some require lenses, etc. I'm losing my mind trying to understand the differences between them all. If anyone has a mount they've used & like, let me know.
Thanks much,
mnr102
Old 28th June 2008, 06:18 PM   #2
Iain McNeill's Avatar
T1/4 LEDs (the leaded ones that look like a top hat with a tall dome) have a plastic insert with a rear clip. You stick the round insert in the panel hole, snap the LED in and secure with the clip. They work good.
Some fancy LEDs come with a chrome bezel and lock nut. Even easier.
Surface mount LED's usually need some kind of acrylic light pipe - a little harder for DIY but still possible. Use these if you want something other than a round indicator.
The rectangular and triangular leaded LEDs are harder because you have to cut a perfect opening in the front panel (there's no bezel available) This is very hard (for me at least - no triangular drill bits)
Old 29th June 2008, 04:58 PM   #3
Thanks for ideas Ian. I ended up with what I believe is first on your list. Mouser part 749-CR-104. It's a span-in panel mount, w/ a retaining ring that gets pressed on from the back.
Thanks again.
RCA PCB Mount Connector GB Algar_emi Group Buys 13 21st February 2009 08:27 PM
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS. Swap Meet 1 22nd December 2006 06:18 AM
Where to Mount X-Over? r0lf- Multi-Way 6 7th August 2004 05:12 PM
should I chuck my P-mount TT? leadbelly Analogue Source 10 15th March 2003 10:22 PM
How do I mount big capacitors in a box? swede Parts 11 12th November 2001 11:57 AM
Page generated in 0.07029 seconds (71.95% PHP - 28.05% MySQL) with 10 queries
