#11 |
Here a model with current mirrors and cascode...a fully scalable design. Just add output sets the needed SOA. It SIM's with rather low distortion and also a good distortion distribution..!!
But must still say that I have a little problem with the split and having complimentary parts handling the signal. The one J-fet amplifier you previously pulled out of the hat....I fancy that... |
#12 | |
I really like the simplicity of this circuit Lineup! And the results look very good as well. |
#13 |
Banned
MiiB,
most of the nice features of the original design are gone. The input cascode is OK, but there`s no need for another VAS. |
#14 |
Very nice circuit Lineup! I know that you like very much symmetrical input stages and you are right on this.
We could use the channel bridging mode to increase the output power, keeping thus the supply voltage in low level instead cascading transistors. In such a case, we need 4 channels (instead the ordinary two) for making a fully symmetrical (balanced) from input to output stereo amplifier. Just an idea, because i have a 2 X 21V / 200VA toroid surplus which can provide an output power (according to bridge mode) of 2 X 70 Wrms / 8 Ohms. |
#15 |
What do you mean.. The VAS is already there...Here I am just setting the current in The VAS by using current mirrors...this lowers the higher order harmonics...
The Cascodes are there so it can be scaled to higher voltages |
#16 |
Banned
I see that, nevertheless, the cascoding transistor is a voltage amplifier. By adding another voltage amplifying stage and altering the common source stage into source follower the design is made more mediocre compared to the original Zenquito. This amp will behave very differently.
#17 |
I like the MiiB 60/50 Volt variant.
The original Zenquito can be made in different flavours. Lower voltage, higher voltage, Class AB, Class A. See here: 2A & DIY Personally I like amplifiers with lower power. It is enough for most cases. It is striking how simple amplifiers can be designed with Lateral MOSFET, 2SK1058/2SJ162. If I was to build a power amplifier I would go this way.
lineup |
#18 |
Banned
OK, now I understand, the topology I had in mind obviously has many names, Zenotron, zenItron, Amperotron...I`m very sorry.
| Strange Variants of the T-Amp | EdT | Class D | 3 | 11th February 2007 10:07 PM |
| 6CY7 Variants | wrenchone | Tubes / Valves | 7 | 23rd December 2006 03:13 AM |
| Q about building the Zenquito amp with 2SK1058 / 2SJ162 | sinigersky | Solid State | 0 | 23rd September 2004 02:15 PM |
| JFET Buffered Gainclone-substitute for "SK170 | hifileslie | Chip Amps | 10 | 21st August 2003 06:09 AM |
| 6H30Pi variants | Jesse | Tubes / Valves | 22 | 9th April 2003 12:09 PM |
| Page generated in 0.08822 seconds (78.71% PHP - 21.29% MySQL) with 11 queries |
